3 members (Otto Skorzeny, Gdads51, 1 invisible),
101
Mod | | | Forums66 Topics128,292 Posts1,058,598 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 50 Member | | Member Joined: Apr 2002 Posts: 50 | Got a 42 Dump and am looking to find wheel cylinders and shoes, any ideas where to look? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | An old Napa catalog shows 40 series 39-50 wheel cylinders front part # 3406. 11/4 diameter. Rear repair kit part # 37. Front repair kit part#8. The brake shoes only go back to 53. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2002 Posts: 50 Member | | Member Joined: Apr 2002 Posts: 50 | | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | IWL,
Are the shoes in good shape? A long while ago, I had a set on my half ton re-lined. I don't know of they can do it on your bigger truck or not. It might be worth a look if the shoes are not junk. | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | I'm fairly sure your truck uses the same kind of huck brakes that my 47 does. You should be able to find the parts at most napa stores. You can have your shoes relined by them, as long as the cores aren't damaged. | | | | | Joined: Mar 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 23 | When I was redoing the brake/master cyls. on my truck, I had them all bored and resleeved with brass or stainless steel(your choice)to original specs.,rebuilt with stock rubber kits,and now use silicone brake fluid. Supposed to be less corrosive and not bothered by moisture. My truck is not a daily driver, it could be but its a 1945 2ton 12'flatbed. I read about this proceedure in This Old Truck/Vintage Truck magazine. I am totally satisfied with this...
KEEP ON TRUCKIN,MAMA... TRUCKIN TILL THE BREAK OF DAY... I SAID,KEEP ON TRUCKIN,MAMA... TRUCKIN MY BLUES AWAY...
