Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (cmayna, 1954gmc9314, ndkid275, SmalltownTRKGuy, KEVINSKI), 201 guests, and 1 robot.
Topics128,292
Posts1,058,590
Members48,492
#202397 02/28/2006 2:41 PM
I
I Offline
Got a 42 Dump and am looking to find wheel cylinders and shoes, any ideas where to look?
Riding in the Passing Lane
An old Napa catalog shows 40 series 39-50 wheel cylinders front part # 3406. 11/4 diameter. Rear repair kit part # 37. Front repair kit part#8. The brake shoes only go back to 53.
1972 Chevy c10 Cheyenne Super
I
I Offline
thanks
IWL,
Are the shoes in good shape? A long while ago, I had a set on my half ton re-lined. I don't know of they can do it on your bigger truck or not. It might be worth a look if the shoes are not junk.
I
I Offline
I'm fairly sure your truck uses the same kind of huck brakes that my 47 does. You should be able to find the parts at most napa stores. You can have your shoes relined by them, as long as the cores aren't damaged.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
When I was redoing the brake/master cyls. on my truck, I had them all bored and resleeved with brass or stainless steel(your choice)to original specs.,rebuilt with stock rubber kits,and now use silicone brake fluid. Supposed to be less corrosive and not bothered by moisture. My truck is not a daily driver, it could be but its a 1945 2ton 12'flatbed. I read about this proceedure in This Old Truck/Vintage Truck magazine. I am totally satisfied with this...
KEEP ON TRUCKIN,MAMA... TRUCKIN TILL THE BREAK OF DAY... I SAID,KEEP ON TRUCKIN,MAMA... TRUCKIN MY BLUES AWAY...
