6 members (rfs56trk, Eisenholtz, 1955 1 Series, tclederman, 5 Window 9434, 32Fordpuchoptop), 89 guests, and 0 robots.
Topics128,046
Posts1,055,618
#202177 02/25/2006 9:37 PM
I just bought new valve covers that have one hole in each one but the ones I have on my truck now have one hole on one side and the other side has two wil the new ones fit on my 350. thanks.
#202178 02/25/2006 10:05 PM
Travis, you don't have a problem, your new covers are made to fit the the old (like 55-64??) staggard head VC bolts and the new (say 65 and newer) straight across bolt pattern. If you notice, nearly all sbc VC gaskets have double holes on one side.
Evan
#202179 02/25/2006 10:12 PM
Travis, you mean the filler/breather/pcv holes on the cover, not the bolt holes on the gasket? - won't make any diff on the cover holes, except you'll hafta plug the excess hole unless you come up w/ something that uses it - if yer talkin the gaskets, then like Evan sez, the double holes are so it fits various years
#202180 02/25/2006 10:18 PM
Sorry. Yes I mean the filler/breather/pcv holes not the gasket holes.
#202181 02/25/2006 10:22 PM
no problem, but if you've got more bits than holes you'll hafta make the extra hole, extra holes, there's plugs available to blank'em
#202182 02/25/2006 10:38 PM
Thanks red.
#202183 02/27/2006 10:24 AM
What goes to the holes in question? If I understand your question,you now have 3 holes,but the new covers only have 2.That means something won't have a place to connect. you might have to eliminate one hose,or maybe Tie it into another one with a T fitting.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
