0 members (),
79
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 74 | I just bought new valve covers that have one hole in each one but the ones I have on my truck now have one hole on one side and the other side has two wil the new ones fit on my 350. thanks. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Travis, you don't have a problem, your new covers are made to fit the the old (like 55-64??) staggard head VC bolts and the new (say 65 and newer) straight across bolt pattern. If you notice, nearly all sbc VC gaskets have double holes on one side.
Evan
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Travis, you mean the filler/breather/pcv holes on the cover, not the bolt holes on the gasket? - won't make any diff on the cover holes, except you'll hafta plug the excess hole unless you come up w/ something that uses it - if yer talkin the gaskets, then like Evan sez, the double holes are so it fits various years
Bill | | | | | Joined: Jan 2006 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 74 | Sorry. Yes I mean the filler/breather/pcv holes not the gasket holes. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no problem, but if you've got more bits than holes you'll hafta make the extra hole, extra holes, there's plugs available to blank'em
Bill | | | | | Joined: Jan 2006 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 74 | | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | What goes to the holes in question? If I understand your question,you now have 3 holes,but the new covers only have 2.That means something won't have a place to connect. you might have to eliminate one hose,or maybe Tie it into another one with a T fitting. Speed | | |
