| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | I have the new shocks installed and it rides well but nothing like a 2006 truck. If I pull into a parking lot the bump hitting the ramp causes my foot to go forward and goose the throttle. I get about three of these jerks before it smooths out. I have moved the seat forward and beefed up the throttle return spring. Am thinking of adding a throttle footrest like on my old jeep. Any good ideas? Mike | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sounds like a personal problem to me! what year? the trans hump is the 'footrest' in my TF trucks - if yer tryin to drive w/ yer foot flat against the pedal, heel right against it and sole on it there's bound to be some reaction to body movement when you bounce on the seat - and your return spring might be too strong so your tensed against it alla time Bill | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Do you have an original throttle pedal set up? Some of these trucks have a different throttle pedal setup if the original engine was swapped for a V8. The length of the pedal neck may be giving you trouble if you are dealing with a "project" or rodded truck. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I have the same problem with my stock '50 throttle. I usually just ride the clutch when I know it is going to happen. Making sure the motor mounts are new and the rear end lash isn't excessive helps.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | you could just move your foot off of the pedal when you are hitting bumps or put the clutch in. I had a suburban that I used to do the same things in all the time. I corrected it by learning to take my foot off the gas when i was going over bumps. It was the cheapest soltion, and it only took a few weeks to relearn a new way.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | weaker return spring will help you be able to "feather" the pedal a little more.
when I read the title of this thread I thought maybe it had something to do with tailgaters or a kid with loud exhaust in your neighborhood :p
Keith If it were easy they'd have grade schoolers doing it! | | |
