2 members (Peggy M, UtahYork), 62 guests, and 1 robot.
Topics128,035
Posts1,055,443
Members48,422
#201183 02/15/2006 2:20 PM
Junior Member
Junior Member
I have the new shocks installed and it rides well but nothing like a 2006 truck. If I pull into a parking lot the bump hitting the ramp causes my foot to go forward and goose the throttle. I get about three of these jerks before it smooths out.
I have moved the seat forward and beefed up the throttle return spring. Am thinking of adding a throttle footrest like on my old jeep.
Any good ideas?
Mike
#201184 02/15/2006 5:26 PM
sounds like a personal problem to me! grin
what year? the trans hump is the 'footrest' in my TF trucks - if yer tryin to drive w/ yer foot flat against the pedal, heel right against it and sole on it there's bound to be some reaction to body movement when you bounce on the seat - and your return spring might be too strong so your tensed against it alla time
#201185 02/15/2006 9:22 PM
Do you have an original throttle pedal set up? Some of these trucks have a different throttle pedal setup if the original engine was swapped for a V8. The length of the pedal neck may be giving you trouble if you are dealing with a "project" or rodded truck.
~ Kimberly
My '54 ... and my '63 and a '59 F100
#201186 02/15/2006 11:24 PM
I have the same problem with my stock '50 throttle. I usually just ride the clutch when I know it is going to happen. Making sure the motor mounts are new and the rear end lash isn't excessive helps.
Paint & Body Shop moderator
#201187 02/15/2006 11:27 PM
you could just move your foot off of the pedal when you are hitting bumps or put the clutch in. I had a suburban that I used to do the same things in all the time. I corrected it by learning to take my foot off the gas when i was going over bumps. It was the cheapest soltion, and it only took a few weeks to relearn a new way.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#201188 02/15/2006 11:30 PM
weaker return spring will help you be able to "feather" the pedal a little more.
when I read the title of this thread I thought maybe it had something to do with tailgaters or a kid with loud exhaust in your neighborhood :p
Keith
If it were easy they'd have grade schoolers doing it!
