1 members (klhansen),
76
Mod | | | Forums66 Topics128,076 Posts1,056,009 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | I can't seem to get the dome light cover off. Is there a right way to do this? Any suggestions? I need to change the bulb and see if it works. Thanks. | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Hi there Magnolia, Its easy all you have to do is squeeze the dome cover at the top and bottom part of the rectangle lense.
good luck
Cliff59 | | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | Thanks! I thought it was an easy answer. The screw driver didn't do it. | | | | | Joined: Jan 2006 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 74 | Is there a way to get the base of the dome light off without breaking the plastic | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | The dome lights usually are screwed on T-rav. Youll find the screws under the dome light cover. | | |
