1 members (carbking),
144
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20084 12/17/2004 3:16 AM | Joined: Oct 2004 Posts: 1 Junior Member | | Junior Member Joined: Oct 2004 Posts: 1 | Can anyone tell me what kind of transmission I have? The numbers on the tran. are GM 30 3743368 k 170 There are 10 splines on the front and 16 splines on the tail. The shifter housing has the number 3741357. The transmission came out of a 56 chevy 3200  | | |
#20085 12/21/2004 11:41 PM | Joined: Mar 2004 Posts: 83 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 83 | If it is the stock trans out of a 56, it will be a SM-420 4spd with the 7.1 to 1 1st gear. This trans was used from 47 to 67 in the 1/2t to 2 1/2 ton model trucks. Hope this helps, Garry
Garry K in Pac Nor West 1948 Chevy PU 235 SM420 4 spd 1932 **** B pu 1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
#20086 12/22/2004 2:40 AM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | A general web search for the casting number 3743368 resulted in the following: http://1967-81camarocarparts.com/catalogPDFs/F2%2002%20transmission.pdf That case casting number is for a 58-63 Saginaw 3-speed. Given the casting date K170, assuming that is a casting date, yours was cast in 1960.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
#20087 12/22/2004 3:53 AM | Joined: Oct 2003 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 66 | The amazin' one sez that you have a broken transmission, and it is now OUT of your truck. :-)
Seriously, I don't have a clue! | | |
#20088 08/30/2005 12:36 AM | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | I see that you know I asked this question before. After I asked last time I started looking and couldn't find one that looked like mine. They had you look at the bolt pattern on the side and all had too many bolts. That is why I asked again. I am pretty sure mine is a saginaw 3-speed now. Thanks for all the help. | | |
