5 members (TexasJim50, Opelika Tom, cmayna, Gdads51, Otto Skorzeny), 92 guests, and 4 robots.
Topics128,185
Posts1,057,203
Members48,465
#20084 12/17/2004 3:16 AM
Junior Member
Junior Member
Can anyone tell me what kind of transmission I have? The numbers on the tran. are GM
30
3743368
k 170
There are 10 splines on the front and 16 splines on the tail. The shifter housing has the number
3741357. The transmission came out of a 56 chevy 3200 grin
#20085 12/21/2004 11:41 PM
If it is the stock trans out of a 56, it will be a SM-420 4spd with the 7.1 to 1 1st gear. This trans was used from 47 to 67 in the 1/2t to 2 1/2 ton model trucks. Hope this helps, Garry
Garry K in Pac Nor West
1948 Chevy PU 235 SM420 4 spd
1932 **** B pu
1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
#20086 12/22/2004 2:40 AM
X
X Offline
A general web search for the casting number 3743368 resulted in the following:
http://1967-81camarocarparts.com/catalogPDFs/F2%2002%20transmission.pdf
That case casting number is for a 58-63 Saginaw 3-speed. Given the casting date K170, assuming that is a casting date, yours was cast in 1960.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#20087 12/22/2004 3:53 AM
The amazin' one sez that you have a broken transmission, and it is now OUT of your truck. :-)
Seriously, I don't have a clue!
#20088 08/30/2005 12:36 AM
Apprentice
Apprentice
I see that you know I asked this question before. After I asked last time I started looking and couldn't find one that looked like mine. They had you look at the bolt pattern on the side and all had too many bolts. That is why I asked again. I am pretty sure mine is a saginaw 3-speed now. Thanks for all the help.
