1 members (Nick in Manitou), 70 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#200307 02/06/2006 7:19 PM
Junior Member
Junior Member
Hi,
I drive my '49 5 window on weekends and only short distances. I would like to drive it more but am a bit nervous about my brakes. They are standard drum brakes. The previous owner had replaced the cylinders about 2 or 3 years ago. I recently adjusted the brakes all around because the pedal was so low. It's not squishy at all just low. It helped a little, but it's still lower than I would like. Funny thing is that as the truck is driven and the engine is at proper running temperature, I get a bit more pedal. If I stomp on the brakes I can lock them up no problem. What am I doing wrong? Is there an adjustment directly at the pedal? Any input here would be greatly appreciated.
Aloha,
Rich
#200308 02/06/2006 8:31 PM
Riding in the Passing Lane
There are 2 adjustments on each wheel. They turn the opposite direction. The caps on the ends of the wheel cylinders turn & all have right hand threads. Draw them up til you get a heavy drag & back it up 2-3 notches. There is an adjustment on the master cylinder. It should have about 1/8 to 1/4 free play till it starts pushing in on the master cylinder. When these brakes are right the pedal should not go down hardly at all. You just apply pressure to it.
1972 Chevy c10 Cheyenne Super
#200309 02/07/2006 3:18 AM
Adjust the pedal rod after you drive it a fair distance. The master being under the floor with the heat makes everything expand a bit and you need to keep the pedal loose enough not to apply pressure after warm-up,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#200310 02/10/2006 7:31 AM
Junior Member
Junior Member
Well I got under the truck and adjusted the push rod. I didn't wait to do it after driving it for a while, but it was a pretty low pedal. I also topped off the fluid which was actually pretty low. It gives me lots of pedal now, and if I find that it's too high after it heats, I will make the adjustment.
Thanks for your help guys. It's good to know that I can always count on my fellow Stovebolters for help.
Aloha,
Rich
