2 members (Stewart2, Hanks custodian), 96 guests, and 8 robots.
Topics128,014
Posts1,055,324
Members48,419
#199783 01/31/2006 10:28 AM
I was wondering if it would be ok to put a truck into storage using moth balls inside to discourage bugs and critters from using the truck. I was reading where it is good to use kitty litter to absorb moisture but I'd like to use moth balls also in the cab to make it unpleasant for any rodents or bugs to use the cab as a nest. Has anyone tried this? Are there any things that can be damaged by this? I'd let the truck air out well before using it. Any thoughts are appreciated.
David
#199784 01/31/2006 10:38 AM
I think a mousetrap or two, and a goodly supply of Irish spring will work nicely.
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#199785 01/31/2006 2:02 PM
Try bounce dryer sheets.They smell better.I put them in my camper to keep mice out.I went to check on the camper last week and there was no sings of any mouse activity.We had a terrible mouse problem last winter but no problem so far this winter.
The crew that works on the \'42 --Sara, Hannah and Abby
#199786 01/31/2006 4:22 PM
We have put mothballs around farm equipment to keep the mice out of them. Simply spread the balls around the truck and mice won't come near it.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#199787 01/31/2006 4:44 PM
I used to use mothballs all the time when I stored my 63 Chevy Conv't. Never had a problem. The best way to get the order out I found was I would park the car in the sun w/top down.
popcorn The Truth is Out There (Kinda of hard to put a top down on a truck tho)Ben
#199788 01/31/2006 5:01 PM
RT1 Offline
Quote
Yep I always use bounce dryer sheets and Irish Spring soap bars in the camper. I have never had any problems with mice. However, I keep the camper in my heated building, so this may help also. smile
-RT1
#199789 02/02/2006 10:34 PM
I have two charcol briquets in a platic potpouri container under my seat,it helps with the musty oder from still hav'n the 57 year old seats in it,hopefully that oder will be gone when my better half re covers them but as far as rodent problems i dont think it will do any thing for that.The dryer sheets sound cool,I'm rob'n the laundry room now
1949 Styleline Special
1972 K5 Blazer
#199790 02/02/2006 10:41 PM
Dryer sheets work great... for awhile.
What happens is that sooner or later the dryer sheets loose their smell, then the little bastards start carrying the sheets off to make nests out of!
For short term, dryer sheets.. for long term, go with moth balls.. or a cat or two!
I discovered that a 5 gallon bucket tipped on its side with some molasas makes a good mouse trap.. they walk into the bucket to get to the molasas then get stuck in it and die.
I found that out on accident.. I have a large water tank I had tipped upside down to keep the rain and wind off some sacks of corn I feed the cows.. there was a mostly empty bucket of molasas under there and at some point it had got tipped over.. then about every other day or so i'd find a dead mouse stuck in it.
Just make sure to pull the dead mice out of there while they're sort of fresh.. if a week or so goes by, they dont come out in one piece!
#199791 02/02/2006 11:36 PM
I have a stray cat that has decided to live under the seat of my 64 inside the shop. no mice at all in that truck. brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#199792 02/03/2006 12:50 AM
Used moth balls for years. the only problem is airing the thing out in spring
#199793 02/03/2006 3:46 AM
Former Workshop Owner
So what do you do with the Irish Spring soap? Do you just take it out of the wrapper? Will one bar keep them out of the cab of a truck, or does it take a several. Does the Irish Spring lose its scent like the dryer sheets, or will it last forever if you scrape the sides occasionally?
I heard about moth balls and dryer sheets, but not the Irish Spring. Sounds like an interesing alternative. Never did care for moth balls.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#199794 02/03/2006 6:39 AM
Thanks for the advice but I'll pass on the Irish Spring thing. I'd get tired of everyone coming by the truck and whistling. :p Seriously though, I'll have to try it.
#199795 02/03/2006 7:30 AM
I would think that the dryer sheets would out last putting a cat in the truck. But, on the other hand, the smell of the cat may actually out last the dryer sheets. . .
Nevermind! grin grin cool
Jim Karras
Orange, CA
'59 Chevy Apache 32 Stepside Pickup
E-mail: [email protected]
Internet: www.59apache.com
