| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 117 | I was wondering if it would be ok to put a truck into storage using moth balls inside to discourage bugs and critters from using the truck. I was reading where it is good to use kitty litter to absorb moisture but I'd like to use moth balls also in the cab to make it unpleasant for any rodents or bugs to use the cab as a nest. Has anyone tried this? Are there any things that can be damaged by this? I'd let the truck air out well before using it. Any thoughts are appreciated. David | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | I think a mousetrap or two, and a goodly supply of Irish spring will work nicely.
Cliff59 | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Try bounce dryer sheets.They smell better.I put them in my camper to keep mice out.I went to check on the camper last week and there was no sings of any mouse activity.We had a terrible mouse problem last winter but no problem so far this winter. | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | We have put mothballs around farm equipment to keep the mice out of them. Simply spread the balls around the truck and mice won't come near it.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | I used to use mothballs all the time when I stored my 63 Chevy Conv't. Never had a problem. The best way to get the order out I found was I would park the car in the sun w/top down.
popcorn The Truth is Out There (Kinda of hard to put a top down on a truck tho)Ben | | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | Originally posted by dad6timz: Try bounce dryer sheets.They smell better.I put them in my camper to keep mice out.I went to check on the camper last week and there was no sings of any mouse activity.We had a terrible mouse problem last winter but no problem so far this winter. Yep I always use bounce dryer sheets and Irish Spring soap bars in the camper. I have never had any problems with mice. However, I keep the camper in my heated building, so this may help also. -RT1 * | | | | | Joined: Dec 2005 Posts: 112 Member | | Member Joined: Dec 2005 Posts: 112 | I have two charcol briquets in a platic potpouri container under my seat,it helps with the musty oder from still hav'n the 57 year old seats in it,hopefully that oder will be gone when my better half re covers them but as far as rodent problems i dont think it will do any thing for that.The dryer sheets sound cool,I'm rob'n the laundry room now
1949 Styleline Special 1972 K5 Blazer
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Dryer sheets work great... for awhile.
What happens is that sooner or later the dryer sheets loose their smell, then the little bastards start carrying the sheets off to make nests out of!
For short term, dryer sheets.. for long term, go with moth balls.. or a cat or two!
I discovered that a 5 gallon bucket tipped on its side with some molasas makes a good mouse trap.. they walk into the bucket to get to the molasas then get stuck in it and die.
I found that out on accident.. I have a large water tank I had tipped upside down to keep the rain and wind off some sacks of corn I feed the cows.. there was a mostly empty bucket of molasas under there and at some point it had got tipped over.. then about every other day or so i'd find a dead mouse stuck in it.
Just make sure to pull the dead mice out of there while they're sort of fresh.. if a week or so goes by, they dont come out in one piece!
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have a stray cat that has decided to live under the seat of my 64 inside the shop. no mice at all in that truck. brian | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Used moth balls for years. the only problem is airing the thing out in spring | | | | | Joined: Nov 2004 Posts: 2,399 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,399 | So what do you do with the Irish Spring soap? Do you just take it out of the wrapper? Will one bar keep them out of the cab of a truck, or does it take a several. Does the Irish Spring lose its scent like the dryer sheets, or will it last forever if you scrape the sides occasionally?
I heard about moth balls and dryer sheets, but not the Irish Spring. Sounds like an interesing alternative. Never did care for moth balls.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jul 2005 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 117 | Thanks for the advice but I'll pass on the Irish Spring thing. I'd get tired of everyone coming by the truck and whistling. :p Seriously though, I'll have to try it. | | | | | Joined: Sep 2004 Posts: 122 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 122 | I would think that the dryer sheets would out last putting a cat in the truck. But, on the other hand, the smell of the cat may actually out last the dryer sheets. . . Nevermind!  | | |
