Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (ShopRag, 46 Texaco, Shade Baby), 147 guests, and 5 robots.
Topics128,283
Posts1,058,519
Members48,490
Junior Member
Junior Member
This business of moving gas tank from behind the seat to under bed of 1950 3100. I've seen lots with filler neck in floor but I want mine in rear panel, hopefully without C notching the frame. I just don't trust mysefl with holding that gas nozzel over my beautiful bed wood.Would appreciate anybody's experience with type of tank required to solve this delima.
P.S. Can get after market tank for under $200. fuel cell not in the budget.
bluenoser, the filler neck on the '47's and '48's come out the right side of the bed side, below the bed floor. Have you considered this alternative?
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
I saw a truck at a car show once that had a fuel filler door fabbed into the trailing edge of the driver side rear fender. it looked really good.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
I've got a fuel cell in my '46 Panel, looks like this,
http://hotrodders.com/gallery/showphoto.php/photo/5177/size/big/cat/500/page/5
http://hotrodders.com/gallery/showphoto.php/photo/5432/size/big/cat/500/page/5
Stainless steel, a friend made it for me to my specs to fit in the frame rails.
I mounted it behind the rear axle and ran the filler neck into the left rear fender like this
http://hotrodders.com/gallery/showphoto.php/photo/19530/size/big/cat/500/page/1
http://hotrodders.com/gallery/showphoto.php/photo/19531/size/big/cat/500/page/1
I don't know about pick-ups but I didn't have to notch frame just a little sheet metal pinch weld area and have a good down flow angle too.
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
BLUENOSER, go to my community webshots there are pictures of my tank install with the filler in the drivers side fender. a bit pricey for the cap, 60.00 and 60.00 for the flanger but the cap can be surface mounted. bothe from airride technologies. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Have mine in the bed and haven't made a mark on the urethane in the last 3 years. just was a easier place to put it.
If ya gotta move the fuel tank, then i'd say putting the filler in the fender with a flush "door" would be the best way to go.
Putting the filler in the bed is a quick way to go about things, but what would you do if you had a full load of gravel and then noticed you needed gas?
http://s67.photobucket.com/albums/h298/1951otter/ use 1951otter and password katiemae in the search
you'll have to scroll down the page after you open the link ... forget the logon bit at the top.
I used the same old filler neck but turned it 180 degrees, fitted (welded) it w/ an external surface plate that attaches to the outside of the bed. The filler neck hole is below the bed wood, there is enough skirt to allow for this. cleaver those chevy designers . . . . It fits at a good angle for the gas nozzle. I then used a 2'' piece of exh. pipe and reduced it to fit (welded to) the 1-1/4'' stock tube. it now flares out to 2'' and the new 16 gal tank has a matching 2'' inlet, coupled it w/ a rubber gas filler hose. Tank has an anti roll vent. The tank is supported by 4 - 1/2'' rods that are screwed into 4 welded nuts under the bed cross steel supports. Everything is double nuted, or lock-tited. The bottom tank supports are 2'' that cross under the tank mounted w/ some sheet rubber.
I kinda like the exposed 'old stock' look of the filler tube in front of the rear fender.
Jim & Caroline
