| | | Forums66 Topics128,191 Posts1,057,364 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 9 Junior Member | | Junior Member Joined: May 2005 Posts: 9 | This business of moving gas tank from behind the seat to under bed of 1950 3100. I've seen lots with filler neck in floor but I want mine in rear panel, hopefully without C notching the frame. I just don't trust mysefl with holding that gas nozzel over my beautiful bed wood.Would appreciate anybody's experience with type of tank required to solve this delima. P.S. Can get after market tank for under $200. fuel cell not in the budget. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | bluenoser, the filler neck on the '47's and '48's come out the right side of the bed side, below the bed floor. Have you considered this alternative? | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | I saw a truck at a car show once that had a fuel filler door fabbed into the trailing edge of the driver side rear fender. it looked really good.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | BLUENOSER, go to my community webshots there are pictures of my tank install with the filler in the drivers side fender. a bit pricey for the cap, 60.00 and 60.00 for the flanger but the cap can be surface mounted. bothe from airride technologies. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Have mine in the bed and haven't made a mark on the urethane in the last 3 years. just was a easier place to put it. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | If ya gotta move the fuel tank, then i'd say putting the filler in the fender with a flush "door" would be the best way to go.
Putting the filler in the bed is a quick way to go about things, but what would you do if you had a full load of gravel and then noticed you needed gas?
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | http://s67.photobucket.com/albums/h298/1951otter/ use 1951otter and password katiemae in the search you'll have to scroll down the page after you open the link ... forget the logon bit at the top. I used the same old filler neck but turned it 180 degrees, fitted (welded) it w/ an external surface plate that attaches to the outside of the bed. The filler neck hole is below the bed wood, there is enough skirt to allow for this. cleaver those chevy designers . . . . It fits at a good angle for the gas nozzle. I then used a 2'' piece of exh. pipe and reduced it to fit (welded to) the 1-1/4'' stock tube. it now flares out to 2'' and the new 16 gal tank has a matching 2'' inlet, coupled it w/ a rubber gas filler hose. Tank has an anti roll vent. The tank is supported by 4 - 1/2'' rods that are screwed into 4 welded nuts under the bed cross steel supports. Everything is double nuted, or lock-tited. The bottom tank supports are 2'' that cross under the tank mounted w/ some sheet rubber. I kinda like the exposed 'old stock' look of the filler tube in front of the rear fender.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
