4 members (Otto Skorzeny, moparguy, delky, 1 invisible), 104 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#199751 01/31/2006 2:06 AM
H all
I have '51 3800 I've recently finished but can't seem to find the right lubricant to stop the clutch from squeaking as it rubs going in and out through the floor. I have the same noise in my allis Chambers 7000.
Any suggestions on what might work best to stop the squeaking?
#199752 01/31/2006 4:57 AM
3B Offline
Hy PaFarmer, I'm assuming that you have tried to adjust the pedal so it doesn't rub, it shouldn't you know.
#199753 01/31/2006 5:04 AM
That or hog it out a bit. The clutch pedal has a nut on it securring it's shaft to the pedal arm, so loosen that shaft a bit and twist it a bit and that should do it.
#199754 01/31/2006 6:41 AM
However there Farmer, That sound is what makes a StoveBolt so "Wonderful" grin
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#199755 01/31/2006 6:53 AM
I'm with Cliff, my 61 makes a great squeak when i depress and release the clutch pedal. It is not too loud or annoying, but it adds to the old truck thing. Someday I will probably grease the hinge thingy, but for now I let it squeak. I think that my pedal is a completely different assembly, mine looks easier to "de-squeak" than yours. Good luck.
-Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#199756 01/31/2006 6:57 AM
My truck had a round, stainless steel 'pin' shoved in by the side. Quiet as a mouse until it came out about two weeks ago...
Sabrina
Sabrina
'54 3100
#199757 01/31/2006 12:36 PM
Thanks for the replies; I kinda like the squeak too but the other half doesn't see tthe charm. I'll try a little adjusting first and if that doesn't work I'll see about making the hole a little bigger.
Glad to hear I'm not the only one.
PAFarmer
#199758 01/31/2006 1:02 PM
2 Offline
PaFarmer..... The reason that your pedels are rubbing on the floor is that the bushings in the pedel shaft are worn and need replacement.
Tom
#199759 01/31/2006 11:01 PM
Riding in the Passing Lane
Could be the cab mounts are sagged.
1972 Chevy c10 Cheyenne Super
#199760 02/01/2006 2:10 AM
Hmmm? worn bushings on the pedal shaft? that could be it.
I don't believe it's the cab mounts. When I redid this old Pennslvania farm truck I got a rust free cab from Oklahoma and all new cab mounts.
I'll have a look and see if there is some play between the pedal and the shaft.
Thanks for the tip.
