8 members (MRMEROTH11, Peggy M, Southerntruck, Jon G, Ponchogl, Oswald, moparguy, Hanks custodian),
123
0
Mod | | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Does anyone know of a good source for a GMC exhaust system? I need all pipes and mufflers. It is a dual exhaust on a '72 1/2-ton with a 402 engine. NAPA doesn't have it and can't get it. I don't want to pay an arm and a leg to have them fabricated. Midas can fabricate for $550. Give me a break. Any good sources would be appreciated. Thanks. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Rick, my Walker book says the exhaust pipes are N.A., a couple of different mufflers and only the left tailpipe are still listed in my book, and it's old. Do you want the numbers I have? | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | hey rick,
if i was you i would shop around at some of the smaller shops in your area. i got the exhaust on my 61, 235 stock manifold single pipe, done for $200. i had some people quote me up to $400 but I hunted around for a few weeks and found another guy who needed my business more and we struck a deal. anyway, i always have more luck when i go through the smaller guys. they typically care more about their customers, cause they have fewer, and in my experience their work is equal to larger shops. i have been burned once or twice, but in the long run the small shops have been a better resource than the big boys.
that being said, if i had a truck with a 402, i would find someone to run me a nice set of straight pipes, w/ no mufflers, that dumped on each side in front of the back tires with a cool slash tip. that would look pretty trick and it would make the job cheaper because their would be no mufflers, and a lot less pipe. just my $.02
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jan 2005 Posts: 24 Junior Member | | Junior Member Joined: Jan 2005 Posts: 24 | You definitely need a hole-in-the-wall type of muffler shop. A decent set of duals should set you back about 200 to 300 dollars. Forget large chain stores like Midas.
Tender caretaker of antique tractors and old trucks.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | My local muffler shop gets $250. He does a nice job & uses heavy gauge pipe. I like 2 1/4 pipes & stock mufflers Or long glasspacks on a big block. Not loud but a nice rumble at idle. I bring em straight out the back with crome tips. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | dont know what exactly your lookin for but have you tried summit or jegs ? i had a 74 chevy 1/2 that had headers on it i bought a kit from summit that had every thing but the mufflers ran all yhe way out back over the axle simple to install . might still have something like that. maybe flowmaster or one of the other companies might offer them also . might be worth a check see.........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | All good advice guys. I had it done at a local shop. $295 for dual system front to rear with 2-1/2" pipe and very heavy gauge steel. I'm very happy with it and it sounds great. I'm convinced the small shops are the way to go. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I agree with these guys. Forget the chain store muffler shops. The "small" guys can get it done for $100 to $150 per side. I like to use the aluminized pipe. It stays shiny longer and doesn't rust out as soon. You can even get some economy performance mufflers that will work OK for a daily driver. Have them connect the two sides of duals together after the mufflers for better balance. | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | glad that you got it sorted out, the little shops can be the best if you earch carefully. enjoy.
