7 members (Shade Baby, Otto Skorzeny, GIJOE298, 1955 1 Series, Cletus1950, Youngin' Tut 59, MickeyP), 125 guests, and 3 robots.
Topics128,147
Posts1,056,806
Members48,454
#199130 01/24/2006 5:04 AM
Anyone out there had any experience adjusting the parking brake AT THE WHEEL HUB? I just adjusted the wheel cylinders and the parking brake cable/rod/etc as described in the manual, and the whole thing just sorta binds up when I push down on the pedal hard...feels like it outta be scrunching the pads down hard on the drums (I really jammed on it), but it doesn't do much of anything and the truck rolls on a very slight grade. Then I saw in the back of the brake section of the Shop Manual that there's a procedure for adjusting a lever and link and eccentric bolt at the hub. Anyone done this? Should it be done every time the brakes are adjusted? I jam on the pedal, and nothing much happens, even after adjusting the pads/cylinders.
Sounds like you don't have the e cable tight enough. Jack up the rear so that your tires are free. You should be able to spin the rear tires by hand at least 2 revolutions. Start tightning the e cable so that you get drag on the rear wheels. Tighten till you only get about 1 1/2 turns when you try to spin it by hand. That should be it. I don't know if its the proper way but its always worked for me. Also, make sure its in neutral and you have blocks in the front. No use putting extra drag in the mix. Cecil.........
