5 members (Donf, Danielbolt, cmayna, rfs56trk, Oswald), 74 guests, and 3 robots.
Topics128,154
Posts1,056,838
Members48,456
#198598 01/17/2006 3:29 AM
Can someone help.I want to put a 4 speed in my 1953-3100 w/closed drive shaft,will a 4 speed open drive shaft from a 1 1/2 ton work
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
Mr.Giant- Welcome to the 'bolt cool
I'm sure someone will come along soon.
Sabrina
Sabrina
'54 3100
Welcome to the 'Bolt!
I am 99% sure that you will have to swap out the entire rear end to put an open driveshaft tranny on that.
They did make a 4 speed that fits the torque tube on the half tons. Check the swapmeet section. There are a lot of guys who rod and they might have a 4 speed that'll work for you. If there's not one posted anywhere, post a request in "Parts Wanted". Someone is probably looking to clear out some garage space.
Another option: A 1/2 ton rear from a later model should work. I think that the axle off of a 55.2-59 will be what you'd need.
Welcome to the Stovebolt!
It can be made to work, but a little hunting around should turn up a torqe tube type 4-speed that would be easier to swap.
#198602 01/17/2006 12:55 PM
2 Offline
Check with Patricks antique trucks in
Arizona. He has all the info and parts you need to make the change.
Mr. Giant,
Let us know what you want to achieve by changing to a 4-speed (torque-tube or open driveshaft).
There are a variety of possible end results, especially if you go to an open driveshaft.
Tim
#198604 01/18/2006 10:36 PM
Tim; What I want to do is also change to ring and pinion to 3.55 and still be able to have a low 1st gear when and if needed, thanks.
Mr.Giant
