Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Svcattle, baldeagle), 145 guests, and 1 robot.
Topics128,274
Posts1,058,432
Members48,489
#197703 01/09/2006 7:47 PM
RT1
Offline
I have been looking for a clock for my 54 for some time now. I have noticed a few clock housings sell on ebay from time to time. (still not sure about spending the money). eek Does anyone know if the 53-54 car clock insert is the same as the truck?
I have a few pics I have acquired, and they sure look the same. grin
-RT1
* smile
#197704 01/09/2006 7:55 PM
Anonymous
Unregistered
Anonymous
Unregistered
To my knowledge they are the same clock unit. I have also seen where TPI or Dolphin also have a clock unit available but no housing. In a past vintage truck mag there was an ad in the classified section of a guy who had some housings made and was selling them. I know I have the issue at home (had a gold bronco on the cover) and will look tonight and send you info by PM.
#197705 01/09/2006 9:02 PM
I wear a watch.
You can buy an awful nice watch for what they want for a NOS Factory clock.
#197706 01/09/2006 9:54 PM
fer about 2 bucks you can get those little digital stick-on jobs, battery included - last a couple years, so yer cost to know how long you sit in traffic, or how late ya are, could be cut to about a buck a year grin
#197707 01/09/2006 10:04 PM
RT1
Offline
Actually the clocks are cheap, it the darn housing that they poke your eyes out on.
Also thought a tach might look good in the housing...
Randy
#197708 01/09/2006 10:32 PM
Anonymous
Unregistered
Anonymous
Unregistered
I have never seen a tach that would fit in that small housing. Other guages such as oil press, temp, fuel, etc would look good evenly spaced on the dash. The quad guages though handle that nicely also.
#197709 01/10/2006 8:30 AM
Autometer makes some very small tachs.
1954 GMC De Luxe COE
#197710 01/10/2006 8:49 AM
I think a tach would look good as well.
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#197711 01/10/2006 11:47 PM
What do those 54 dash clocks sell for?
If you didn’t skin a knuckle while you were working on your truck, you weren’t working hard enough!
53 5window 1/2 ton
54 3window 1/2 ton
#197712 01/11/2006 3:13 AM
The '53/'54 car clock works in the truck housing. I have seen them sell on eBay for $25-$75, depending on condition.
The \'54 truck clock is wind-up (and has a light bulb). There were two car clocks, one wind-up and the other electric (both with light bulb and both fit into the truck clock-housing).
Some people think the winder on the car clock is in a different position than on the truck clock. I think they were the same part number and the winder was just came in a different location from the manufacturer.
#197713 01/12/2006 6:02 PM
RT1
Offline
Call me crazy (not you Fred) but I just got a housing on ebay. grin One step at a time, now I can look for a clock.
Thanks you for all the info provided.
-Randy
(RT1)
* grin
#197714 01/12/2006 6:28 PM
Junior Member
Junior Member
The 53 & 54 car clock element was identical to the ones used on the 54 55.1 truck.
A wristwatch is OK, a cheapo digital stuck to the dash is OK But...
Nothing beats the real thing.
#197715 01/12/2006 6:41 PM
why would you buy the housing with-out the clock...that is crazy grin
Redryder pix
My Hotrod
#197716 01/12/2006 6:42 PM
Are those Chinese knock-offs?
Stuart
#197717 01/12/2006 6:59 PM
Quote
Stuart
Looks like they got knocked off of somthing.. Madonas bra, perhaps?
#197718 01/12/2006 7:03 PM
RT1
Offline
she has three now?
#197719 01/12/2006 7:07 PM
with each tit of the clock grin
Redryder pix
My Hotrod
#197720 01/12/2006 7:18 PM
Junior Member
Junior Member
I like to use the rare electric clock elements.
#197721 01/12/2006 7:32 PM
OTPW,
The three clocks in your first photo all have the widing/adjuster at 9 o'clock. Your last photo (right above this reply) has the (winder/)adjuster at 7 o'clock and you seem to be saying that it is the electric clock. Have you seen an electric clock with an adjuster at 9 o'clock (both my wind-up clocks have the winder/adjuster at 7 o'clock)?
Tim
#197722 01/12/2006 7:48 PM
RT1
Offline
Tim,
You don't have any part numbers by chance? for the clocks....
-Randy
#197723 01/12/2006 9:30 PM
Junior Member
Junior Member
The 53/54 car & the 54/55.1 truck clock part numbers are the same.
Spring wound clock GM # 986633
Electric clock GM # 986634
