2 members (Nick in Manitou, walterhvogel), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#197281 01/05/2006 5:07 PM
Junior Member
Junior Member
I'm ready to purchase the 6 lug disc brake conversion from CCP but my question is,I don't have room for the powermaster cylinder with my stock four speed a'm I shooting myself in the foot with just the dual manual master cylinder or should I buy the one that fits on the firewall and it won't be stock. thanks for your input.
Doug
#197282 01/05/2006 9:20 PM
I have the CCP dual manual master in my 49 with the 6 lug disc kit up front. It stops great. I like the feel of the manual better than the power anyway. I would go power disc only if your gonna do a V8 conversion. One thing I will warn you about is after I intsalled my disc kit, the turning radius was horrible. The caliper brackets were hitting the king pin lock bolt. You will have to either grind the lock bolt head down or grind a little off the brackets. Just a heads up on that cause I drove around for a month doing 10 point turns.
:rolleyes:
#197283 01/05/2006 9:24 PM
Junior Member
Junior Member
thanks for the info on grinding,did you also update to the tapered wheel bearings?
#197284 01/06/2006 6:45 AM
You also can get kevlar linings for the old drums and they REALLY make a difference. www.praisedynobrake.com I have them on my 59 and they work very well.
#197285 01/06/2006 5:02 PM
Yes, I did go to the tapered wheel bearings. The hardest part of the swap was getting the old brake drums off of the spindles. Lots of drilling and beating. grin Kinda fun though.
#197286 01/06/2006 6:51 PM
Junior Member
Junior Member
Thanks for all the input I placed the order last night I even ordered extra floor access plug one of the sites I was reading up on installation said this was a must will see
#197287 01/06/2006 6:52 PM
Junior Member
Junior Member
#197288 01/06/2006 6:57 PM
I just cut the access hole bigger and screwed a piece of heavy gauge sheet metal over the hole. Works great, cheap and give me plenty of access. Good luck. wink
