2 members (baldeagle, homer52),
36
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 33 Junior Member | | Junior Member Joined: Oct 2005 Posts: 33 | I'm ready to purchase the 6 lug disc brake conversion from CCP but my question is,I don't have room for the powermaster cylinder with my stock four speed a'm I shooting myself in the foot with just the dual manual master cylinder or should I buy the one that fits on the firewall and it won't be stock. thanks for your input.
Doug | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I have the CCP dual manual master in my 49 with the 6 lug disc kit up front. It stops great. I like the feel of the manual better than the power anyway. I would go power disc only if your gonna do a V8 conversion. One thing I will warn you about is after I intsalled my disc kit, the turning radius was horrible. The caliper brackets were hitting the king pin lock bolt. You will have to either grind the lock bolt head down or grind a little off the brackets. Just a heads up on that cause I drove around for a month doing 10 point turns. :rolleyes: | | | | | Joined: Oct 2005 Posts: 33 Junior Member | | Junior Member Joined: Oct 2005 Posts: 33 | thanks for the info on grinding,did you also update to the tapered wheel bearings? | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | You also can get kevlar linings for the old drums and they REALLY make a difference. www.praisedynobrake.com I have them on my 59 and they work very well. | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Yes, I did go to the tapered wheel bearings. The hardest part of the swap was getting the old brake drums off of the spindles. Lots of drilling and beating.  Kinda fun though. | | | | | Joined: Oct 2005 Posts: 33 Junior Member | | Junior Member Joined: Oct 2005 Posts: 33 | Thanks for all the input I placed the order last night I even ordered extra floor access plug one of the sites I was reading up on installation said this was a must will see | | | | | Joined: Oct 2005 Posts: 33 Junior Member | | Junior Member Joined: Oct 2005 Posts: 33 | Thanks for all the input I placed the order last night I even ordered extra floor access plug one of the sites I was reading up on installation said this was a must will see | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I just cut the access hole bigger and screwed a piece of heavy gauge sheet metal over the hole. Works great, cheap and give me plenty of access. Good luck.  | | |
