11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 6 Junior Member | | Junior Member Joined: Dec 2005 Posts: 6 | Can someone help me fing a listing for an AGCA 326900 casting number on the block. My 49 3/4 ton has this number and I would like to know more about it. Thanks | | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | Try this Good luck Richard | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | AGCA = possibly means 1949 series 3600,3800 216ci truck engine.
326900 = sequence number, don't know what it means . 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Bowtietim is correct about the AGCA prefix.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Dec 2005 Posts: 6 Junior Member | | Junior Member Joined: Dec 2005 Posts: 6 | Thanks guys, Bowtietim I hope your right because the truck is a 1949 Chev 3600 and since it is in very good running condition I was hoping that the engine was the original. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Here's a old list of 235 Engine prefixes from my file:
Chev 41-49 The 235 can be distinguished from the 216 by the following prefix- '41 AG,AL '42 BG,BL '46 DDA,DDM,DEA,DEM(2nd design) '47 EDA,EDM,EEA,EEM '48 FDA,FDM,FEA,FEM '49 GDA,GDM,GEA,GEM
So your '49 may be a 235, look at the side of the pan (driver's side) for #235 stamped about mid way. This number you listed appears to be stamped number (at the distributor), you need to locate the casting number also on the right side but lower on the block and foreward. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Block casting numbers for 48-49: 216-3835253 235-3835309 | | |
