4 members (cmayna, baldeagle, MNSmith, 46 Texaco), 87 guests, and 5 robots.
Topics128,018
Posts1,055,342
Members48,419
#19628 11/01/2004 5:53 AM
Junior Member
Junior Member
Well I feel perty dumb...I mostly work on old ford trucks I'm not going to lie but I recetly got a early 60's chevy 3/4ton 4x4 thats full of rust with a strong drivetrain (except motor) that i'm gona be making in to a cab and chassis mud truck here the Q I'm working on the engine I perty sure it's a 292 but not positive it has a 4 speed tranny I'm pulling the motor and i cant find the bolts to sperate the tranny and engine wich is funny cause i'm not mechanicly chalenged....I think i found the top two but i've been looking every where and i cant find them can i unbolt the tranny fronm the engine and bellhousing and just pull them apart?? or can some one show me with a picture or give me a good description of where the bolts are? I've got a running motor waiting to be put in or i also have the 350 bellhousing for this tranny so i want this motor out can some one help this me...
#19629 11/01/2004 6:00 AM
Pull the cover tin off the bottom of the bellhoushing, I think you will find the two missing bottom bolts. They remove from the inside of the bellhousing on trucks.
Lonnie
#19630 11/01/2004 6:04 AM
Junior Member
Junior Member
are they pointed towards the engine or the tranny cause i found those but they are on the tranny side??
#19631 11/01/2004 3:02 PM
They are on the engine side.
Not quite as lean
Not quite as mean, but
Still a Marine!
#19632 11/01/2004 5:45 PM
Yeah, ya gotta pull the flywheel cover off and then look inside, towards the bottom on right and left. The bottom bolts thread into tranny whereas the top two bolts thread into bellhousing.
Find the bottom of the pressure plate and then go a few inches to the right and look for a 3/4" bolt head (inside bellhousing). Repeat for left.
-David
Kustoms-and-Sleds
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#19633 11/01/2004 6:05 PM
have fun. i pulled my 235 out around a month ago and what should take 2 hrs took 4 cuz my dad and i couldn't find the bolts. i accidently took apart my tranny. oops
#19634 11/02/2004 12:11 AM
Riding in the Passing Lane
You have to pull the trans. first. Than remove
the clutch & flywheel. Now you can get to the
bell housing to engine bolts. smile
1972 Chevy c10 Cheyenne Super
