4 members (Woodcmiami, Bill Hanlon, Gray_Ghost, J Lucas), 114 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
Junior Member
Junior Member
I am doing a frame up on a 55 short bed, big window. What are the pros and cons of relocating the fuel tank? Is there a "best location" or type of tank if I do relocate?
Gary in my opinion out of the cab is the best start and between the frame rails is a safe place, Cant say enough about plastic, doesnt rust and last forever, just look in any land fill, ther are plenty of OEM tanks in junk yards, as to were that can depend on what your using the truck for. You would think with minor bracket mods they would mount up??? Never done it myself though!!!Dale
Gary, I agree that out of the cab is best, and that is why I moved my tank to behind the axle when I done my restoration on my '56 short bed. I got a universal plastic tank from Yogi's, along with a 0-30 OHM sending unit to match up with the original guage. They had different adaptions for fueling, but I chose to fuel thru-bed and used a lockable fuel door mounted in the bedwood. I'm real happy with the results!
Junior Member
Junior Member
Brian - Thank you..are any of your truck's pictures posted anywhere? Gary
Gary,
You can click on my profile and see it, or look in the Gallery here on the SBP and look under 1956. There has been a lot of pro's and con's on this subject in the past, but for me, the SAFE thing to do was relocate the tank.
