1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 15 Junior Member | | Junior Member Joined: Oct 2005 Posts: 15 | Anyone know of a cam for a 235 or 216 that gives the engine a rough idle.
You never really learn to swear until you learn to drive.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 52Shovelay,
A flat cam!
Stuart | | | | | Joined: Oct 2005 Posts: 15 Junior Member | | Junior Member Joined: Oct 2005 Posts: 15 | You referring to a flat tappet cam? If so, who makes it and where could I get one?
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | He means flat, as in worn out. I'm (we're) sure you mean a cam that gives a lopy idle as in over-cammed, correct? Scott | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 52Shovelay,
I was funnin you! There are a bunch of cams for these engines, but I am not sure you can get a off the shelf item that will lope. The combination of lift and overlap (?) that would create a noticeable lope would probably require a bunch of other engine mods...at the very least carburetion and exhaust.
I have a feeling the cam gurus are lurking about and will show themselves soon..hold tight!
Stuart | | | | | Joined: Oct 2005 Posts: 15 Junior Member | | Junior Member Joined: Oct 2005 Posts: 15 | Thanks ya'll, Ya'll hit the nail on the head, I want a lopey idle cam like you find in abundance for small block chevys. I've got a couple of 216s and 235s sittin around the shop. I'm thinking about rebuilding one to see just what I can make it sound like. I still have got a lot to learn about these old stright sixes, so what I'm thinking about doing to them may not be possible. Thanks again and merry christmas.
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Mine has a pretty sweet little lope. I wish I had the specs handy for you. I bought it in the late 70s when Isky listed a 3/4 cam and a full race. Guess which one I had to have. Hint: the speed shop guy told me that if I bought the 3/4 I was paying good money for a stock cam. As mentioned earlier, It is in an engine with a fresh rebuild at the time, dual carbs, headers, etc. I like it. | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | 52, why not give the guys at Delta Cam up in Tocoma, Wahington a call. http://www.deltacam.com/index.php They did me well and at a price that just made sense. They might even be able to take your cam, as they did mine, and turn it into your wish. | | |
