4 members (Wally / Montana, 59 fleet, Paul_WNC, Gdads51), 96 guests, and 1 robot.
Topics128,051
Posts1,055,734
#195723 12/19/2005 2:24 AM
Junior Member
Junior Member
Anyone know of a cam for a 235 or 216 that gives the engine a rough idle.
You never really learn to swear until you learn to drive.
#195724 12/19/2005 3:15 AM
52Shovelay,
A flat cam!
Stuart
#195725 12/19/2005 3:37 AM
Junior Member
Junior Member
You referring to a flat tappet cam? If so, who makes it and where could I get one?
#195726 12/19/2005 3:57 AM
He means flat, as in worn out. I'm (we're) sure you mean a cam that gives a lopy idle as in over-cammed, correct?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#195727 12/19/2005 4:03 AM
52Shovelay,
I was funnin you! There are a bunch of cams for these engines, but I am not sure you can get a off the shelf item that will lope. The combination of lift and overlap (?) that would create a noticeable lope would probably require a bunch of other engine mods...at the very least carburetion and exhaust.
I have a feeling the cam gurus are lurking about and will show themselves soon..hold tight!
Stuart
#195728 12/19/2005 5:12 AM
Junior Member
Junior Member
Thanks ya'll,
Ya'll hit the nail on the head, I want a lopey idle cam like you find in abundance for small block chevys. I've got a couple of 216s and 235s sittin around the shop. I'm thinking about rebuilding one to see just what I can make it sound like. I still have got a lot to learn about these old stright sixes, so what I'm thinking about doing to them may not be possible. Thanks again and merry christmas.
#195729 12/20/2005 2:52 AM
Mine has a pretty sweet little lope. I wish I had the specs handy for you. I bought it in the late 70s when Isky listed a 3/4 cam and a full race. Guess which one I had to have. Hint: the speed shop guy told me that if I bought the 3/4 I was paying good money for a stock cam. As mentioned earlier, It is in an engine with a fresh rebuild at the time, dual carbs, headers, etc. I like it.
#195730 12/20/2005 3:02 AM
52,
why not give the guys at Delta Cam up in Tocoma, Wahington a call. http://www.deltacam.com/index.php
They did me well and at a price that just made sense.
They might even be able to take your cam, as they did mine, and turn it into your wish.
