| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Not sure where this belongs so I’ll try here.
Does anyone know how to get the windshield wiper motor out of my ‘41? I have the blade and arm off. I also have the inside cover and the entire header cover off.
My problem is I can’t see how to get the large (1/2” diameter) lug off on the outside. I’m sure it must come off before I can unscrew the chrome nut and push the shaft through to the inside of the cab. It appears that there is a very small (about 1/8” diameter splined shaft coming through the body from the wiper motor which is somehow engaged into the ½” diameter lug. Maybe I just need to pry the lug off of the small 1/8 spline but I’m sorta afraid of braking it if there is something else holding it on. Help ??? | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I'm going to move this to general truck to to gain broader exposure.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2001 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 96 | In the middle of the lug there is a pin about the size of the lead in a pencel that goes stright thru the lug and shaft. You can push it out either way as it is a straight pin. | | | | | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | I just removed the wiper motor from my '40 last week. I just unscrewed the nut and the motor came right out. Its a Fickens getting rebuilt noew.
Steve | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Thanks for the info. Now that I have it all apart and cleaned up I can see the small pin. The ½” lug was so chewed up by rust and probably more than a few arm replacements I did not see the pin before.
I got it apart by splitting a few ¼” flat washers and placing them between the chrome retaining nut and the lug. I then gingerly backed off the nut and it pushed the lug and its brass insert off of the 1/8” splined shaft. | | |
