6 members (Gdads51, Ponchogl, Otto Skorzeny, Wayne67vert, BillyDon, carbking), 126 guests, and 4 robots.
Topics128,272
Posts1,058,316
Members48,485
#195649 01/24/2006 4:28 AM
Not sure where this belongs so I’ll try here.
Does anyone know how to get the windshield wiper motor out of my ‘41? I have the blade and arm off. I also have the inside cover and the entire header cover off.
My problem is I can’t see how to get the large (1/2” diameter) lug off on the outside. I’m sure it must come off before I can unscrew the chrome nut and push the shaft through to the inside of the cab. It appears that there is a very small (about 1/8” diameter splined shaft coming through the body from the wiper motor which is somehow engaged into the ½” diameter lug. Maybe I just need to pry the lug off of the small 1/8 spline but I’m sorta afraid of braking it if there is something else holding it on. Help ???
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#195650 01/24/2006 10:11 PM
I'm going to move this to general truck to to gain broader exposure.
Paint & Body Shop moderator
In the middle of the lug there is a pin about the size of the lead in a pencel that goes stright thru the lug and shaft. You can push it out either way as it is a straight pin.
I just removed the wiper motor from my '40 last week. I just unscrewed the nut and the motor came right out. Its a Fickens getting rebuilt noew.
Steve
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
Thanks for the info. Now that I have it all apart and cleaned up I can see the small pin. The ½” lug was so chewed up by rust and probably more than a few arm replacements I did not see the pin before.
I got it apart by splitting a few ¼” flat washers and placing them between the chrome retaining nut and the lug. I then gingerly backed off the nut and it pushed the lug and its brass insert off of the 1/8” splined shaft.
