7 members (Samantha, cmayna, 55shaker, Bill Hanlon, TooMany2count, 1955 1 Series, Otto Skorzeny),
102
Mod | | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19540 04/08/2004 9:50 PM | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 |
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | |
#19541 04/08/2004 9:54 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | | | |
#19542 04/09/2004 12:05 AM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Hey, this is an engine post in the engine shop. Let me tell you, I dance a g&^%^amm jig every time my 235 blat-blats to life. chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#19543 04/09/2004 1:03 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | |
#19544 04/09/2004 5:17 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | | | |
#19545 04/09/2004 5:30 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Now that I have replaced the points and condenser, I can't believe how quickly my 235 fires up. It has always brought a smirk to my face.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#19546 04/09/2004 1:01 PM | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | I guess I would look like this right now. :mad: :mad: I drove mine to the gas station after adding a rebuilt carb, new wires and a cap. It ran so nicely I put on the new hubcaps to show it off. Got to the gas station, put in the non-ethanol stuff to be good to my baby, and it never sparked since I turned the key off. Driving it home on a tow rope wasn't my idea of fun. My post is up on the electrical board, but since you started it, I thought I'd whine and gripe. Thank you for allowing my grumbling... | | |
#19547 04/09/2004 1:25 PM | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | I got a 235 hadn't been started in almost 8 mos. fired right up | | |
#19548 04/09/2004 2:21 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Jake, is your problem fuel or fire related?
#19549 04/09/2004 4:31 PM | Joined: Apr 2001 Posts: 162 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 162 | I hear it running in my head. Vroommmmmm.
Photo by Logan Age 6
[img]http://home.mchsi.com/~tpetty/wsb/media/129404/site1029.jpg[/img]
53 3100 1929 Ford Roadster Pickup 1934 Ford Pickup 68 Plymouth Satellite RR Clone 2 Door My Fleet
#19550 04/09/2004 6:26 PM | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | Chip,
I'm 99% sure it's fire related. I'm hoping to do some testing today. | | |
#19551 04/09/2004 7:57 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Yup, check for power from switch to ign system. Check each component. Check to make sure you're getting power to ignition when key is in 'start' and 'run' positions. Force the coil to spark with a jumper wire from battery. Check ballast resistor and points with voltmeter/testlight. Check ign module if solid-state. Check grounds & primary circuit wiring. Check for fouled sparkplugs, make sure rotor is turning, check rotor position to TDC, etc.
good luck
chip
#19552 04/10/2004 5:12 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Chip your a "got da-n genius". It would be a waste to make you an officer.  :-) | | |
#19553 04/10/2004 2:45 PM | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | My new look, Checked the wire between the coil and distributor, seems suspicious. Fiddled with it a little more and it snapped off. Cleaned and re-crimped the end, touched the starter and off we go. Drove the heck out of it with very satisfactory results. Thanks for the suggestions!!! | | |
