| | | Forums66 Topics128,284 Posts1,058,525 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 18 New Guy | | New Guy Joined: Jan 2005 Posts: 18 | looking for ideas here. have 51 GMC 1/2T longbed. want to install stake rack. each side panel has 3 stake pockets, how can i support the upright board in the stake pocket in the front two pockets. rear pocket has bolts protruding inside at bottom from bracket. front two pockets are open all the way to the filler panel. not sure if i want to drill thru nice new side panel stake racks to install a stop or not.
any ideas?? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | cut the board as a tenon, larger board than the hole cut down to fit with a lip to support it. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Install a stop 6'' down. You could come up from below and bolt through the bottom. This is the 'blind' hole method, not seen from any angle. or A 51 has slanted upper bed rails. Place your metal stake and weld a small flat plate the same angle as the rail. Drill a 5/16'' or 3/8''hole and bolt in situ. or Drill a hole in the verticle stake pocket, about 3-4'' down and place a 3-3.5'' bolt through the wider portion of the pocket.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
