Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 182 guests, and 3 robots.
Topics128,284
Posts1,058,523
Members48,490
#195476 12/15/2005 4:38 PM
looking for ideas here. have 51 GMC 1/2T longbed. want to install stake rack. each side panel has 3 stake pockets, how can i support the upright board in the stake pocket in the front two pockets. rear pocket has bolts protruding inside at bottom from bracket. front two pockets are open all the way to the filler panel.
not sure if i want to drill thru nice new side panel stake racks to install a stop or not.
any ideas??
#195477 12/15/2005 4:43 PM
cut the board as a tenon, larger board than the hole cut down to fit with a lip to support it. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#195478 12/15/2005 5:03 PM
Install a stop 6'' down. You could come up from below and bolt through the bottom. This is the 'blind' hole method, not seen from any angle.
or
A 51 has slanted upper bed rails. Place your metal stake and weld a small flat plate the same angle as the rail. Drill a 5/16'' or 3/8''hole and bolt in situ.
or
Drill a hole in the verticle stake pocket, about 3-4'' down and place a 3-3.5'' bolt through the wider portion of the pocket.
Jim & Caroline
