1 members (Leo), 104 guests, and 1 robot.
Topics128,049
Posts1,055,743
Bondo Artiste
Bondo Artiste
smile
~ Phillip
wink
Hey, this is an engine post in the engine shop. Let me tell you, I dance a g&^%^amm jig every time my 235 blat-blats to life. grin grin grin
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
grin wink cool smile
235 or 283, just can't keep'em down
You saw me huh? grin grin big grin every time I start the old 216 . smile smile
grin Wonderful feeling . grin
Now that I have replaced the points and condenser, I can't believe how quickly my 235 fires up. It has always brought a smirk to my face.
Craig
I guess I would look like this right now. :mad: :mad: frown frown
I drove mine to the gas station after adding a rebuilt carb, new wires and a cap. It ran so nicely I put on the new hubcaps to show it off.
Got to the gas station, put in the non-ethanol stuff to be good to my baby, and it never sparked since I turned the key off.
Driving it home on a tow rope wasn't my idea of fun.
My post is up on the electrical board, but since you started it, I thought I'd whine and gripe.
Thank you for allowing my grumbling...
I got a 235 hadn't been started in almost 8 mos. fired right up
Jake, is your problem fuel or fire related?
I hear it running in my head. Vroommmmmm.
Photo by Logan Age 6
[img]http://home.mchsi.com/~tpetty/wsb/media/129404/site1029.jpg[/img]
53 3100
1929 Ford Roadster Pickup
1934 Ford Pickup
68 Plymouth Satellite RR Clone 2 Door
My Fleet
Chip,
I'm 99% sure it's fire related. I'm hoping to do some testing today.
Yup, check for power from switch to ign system. Check each component. Check to make sure you're getting power to ignition when key is in 'start' and 'run' positions. Force the coil to spark with a jumper wire from battery. Check ballast resistor and points with voltmeter/testlight. Check ign module if solid-state. Check grounds & primary circuit wiring. Check for fouled sparkplugs, make sure rotor is turning, check rotor position to TDC, etc.
good luck
chip
Chip your a "got da-n genius". It would be a waste to make you an officer. grin :-)
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
My new look, grin grin grin
Checked the wire between the coil and distributor, seems suspicious. Fiddled with it a little more and it snapped off. Cleaned and re-crimped the end, touched the starter and off we go. Drove the heck out of it with very satisfactory results.
Thanks for the suggestions!!!
