| | | Forums66 Topics128,151 Posts1,056,989 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | Dear Experts,
What sizes compare to the 1946 one ton truck? I mean would a fender from a 1.5 ton 1946 chevy truck fit the one ton and what about doors, hoods etc? Are there fabricaters out there that can sell me fenders, headlights, etc. Also what about taillights-how are they supposed to look? | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | The cabs are the same on all the '46 trucks.. so are the hoods. That means the cab and hood from a '46 1/2 ton will fit on everything up to a 2 ton.
Hoods are the same way.. I swapped the hood off my '46 2 ton with the one on my 1/2 ton.. perfect fit. Grills outta be interchangable, too.
The only thing that I think would be different is the front fenders.. the 1.5 and 2 ton trucks have bigger fenders to accomidate the bigger tires.. i'm not really sure what size tires they put on a 1 ton '46.
Headlight buckets are all the same from 1/2 to 2 ton.
As far as what the original tail LIGHT (there was only one stock) would have looked like, it would have been on the drivers side, and had a T shaped bracket hanging below it for the licence plate to attach.
| | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | Does this mean that 1/2 ton fenders will fit on a one ton Or are 1 tons juist unique? | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I honestly dont know what tires they put on a 1 ton to say if they'll fit.. but it'll use one size or the other fender.
The 1/2 ton and 3/4 tons generally have 16" tires on them stock (the 3/4 tons just have more lugs) and the front fenders are interchangable.
My guess would be if your tires are 16" or smaller, that the 1/2 ton and 3/4 ton fenders would fit. If they're larger than 16", you'll probably need fenders off a 1.5 or 2 ton.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | simplified, the 1T sheet metal is all the same as the 1/2T -just pop into the 41-46 gallery and start goin thru the entries, you'll find pics of the details in someone's page - I haven't heard of any reproductions for the 41-46 sheetmetal, but if you check some of the suppliers on the links page, you'll prolly find some patch panels I guess in Korea you have a hard time finding another truck to scrounge parts from! Bill | | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | I am in Korea, but thats not forever. My 1946 is in OHIO right now. The truck will never come here and in june I will be going there to move it. This time next year I will start the work, but that gives me plenty of time to assemble information from you. | | |
