6 members (Bill Hanlon, Cletus1950, Rustnut, Bucker, 52Carl, frogfarmer), 81 guests, and 2 robots.
Topics128,178
Posts1,057,063
Members48,460
Dear Experts,
What sizes compare to the 1946 one ton truck? I mean would a fender from a 1.5 ton 1946 chevy truck fit the one ton and what about doors, hoods etc?
Are there fabricaters out there that can sell me fenders, headlights, etc.
Also what about taillights-how are they supposed to look?
The cabs are the same on all the '46 trucks.. so are the hoods. That means the cab and hood from a '46 1/2 ton will fit on everything up to a 2 ton.
Hoods are the same way.. I swapped the hood off my '46 2 ton with the one on my 1/2 ton.. perfect fit. Grills outta be interchangable, too.
The only thing that I think would be different is the front fenders.. the 1.5 and 2 ton trucks have bigger fenders to accomidate the bigger tires.. i'm not really sure what size tires they put on a 1 ton '46.
Headlight buckets are all the same from 1/2 to 2 ton.
As far as what the original tail LIGHT (there was only one stock) would have looked like, it would have been on the drivers side, and had a T shaped bracket hanging below it for the licence plate to attach.
Does this mean that 1/2 ton fenders will fit on a one ton Or are 1 tons juist unique?
I honestly dont know what tires they put on a 1 ton to say if they'll fit.. but it'll use one size or the other fender.
The 1/2 ton and 3/4 tons generally have 16" tires on them stock (the 3/4 tons just have more lugs) and the front fenders are interchangable.
My guess would be if your tires are 16" or smaller, that the 1/2 ton and 3/4 ton fenders would fit. If they're larger than 16", you'll probably need fenders off a 1.5 or 2 ton.
simplified, the 1T sheet metal is all the same as the 1/2T -just pop into the 41-46 gallery and start goin thru the entries, you'll find pics of the details in someone's page - I haven't heard of any reproductions for the 41-46 sheetmetal, but if you check some of the suppliers on the links page, you'll prolly find some patch panels
I guess in Korea you have a hard time finding another truck to scrounge parts from!
I am in Korea, but thats not forever. My 1946 is in OHIO right now. The truck will never come here and in june I will be going there to move it. This time next year I will start the work, but that gives me plenty of time to assemble information from you.
