3 members (78buckshot, klhansen, 1 invisible), 152 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#195288 12/12/2005 3:43 PM
Junior Member
Junior Member
Were is the vin located ,did they use the orig eng, # or the body tag # which is
Model # AC101 Serial # 12225
Are there any repo vin tags or ID tag availible
by the way this is in Calif so anyone know what they used as the vin # .Was it the engine # or the model /serial # Thanks Chris
#195289 12/12/2005 5:10 PM
Chris - I think your 40 is going to be like my 46. There are no "vin" numbers on them. There should be a metal tag on the right side of the cowel. Which from the numbers you gave I assume is still there. This is what the CHP will use to register your truck.
If you don't have the cowel tag the CHP will issue you a "blue tag" with a new ID number for your truck. This is what I had to do, even though I had the numbers off the ID plate (but no plate).
I did order a repo plate and stamped my numbers into it but the blue tag is still the registration number.
Good luck with your project, it sounds like a good one.
George
#195290 12/12/2005 5:34 PM
Junior Member
Junior Member
George ,Thanks for the info, I figure the tag I have is what it should be.When you say right side of the cowl is that looking at it or sitting in the cab looking out.Is the AC101 -12225 The correct body tag #s. Chris
#195291 12/12/2005 7:36 PM
'right side' = passenger side
Just after the passenger side door, on the cowl area under the hood, there outta be a metal plate that has stuff like the vehicles GVR, MFG, etc.. on that plate the vehicle serial number should be stamped.
I've heard of California 'VIN' numbers being the original serial number, the engine number, a combination of both, or a totally unique number all together.
Guess it just depends on their mood that particular day, but it seems like in all cases, a new plate was issued with the number on it.. in some cases, the original mfg tag was removed and the state issued plate installed in its place.
#195292 12/12/2005 7:46 PM
Junior Member
Junior Member
Ya I guess it all depends on there mood, they are pretty easy were I am at , they will make me do a
vin verification which is no big deal,Thanks for the info. Chris
#195293 12/12/2005 9:21 PM
The ID tags are different on GMC and Chevy. The original GMC ID tag was on the interior firewall above the transmission in 1940.
GMC ID tags are not reproduced.
#195294 12/13/2005 4:00 AM
I
I Offline
So is it a Chevy? Post some pics if you get a chance.
I had to blue tag my 1940 3/4 ton. The CHP was actually very good about it.
#195295 12/13/2005 5:59 AM
Junior Member
Junior Member
It's a GMC and I sent in pictures to be posted unless there another area to quick post pictures.
I have the ID with the model# and serial # and will just use that as the vin # pluss I have the orig 1940 plates for it.Chris
#195296 12/13/2005 2:03 PM
46forme can you tell me where you got the repo plate thanks
The crew that works on the \'42 --Sara, Hannah and Abby
#195297 12/13/2005 2:33 PM
Chris,
I was just about to post that your \'Burb is now in the Gallery.
Not sure if this will help. But let me know if it gives you more info to add to your page (to help others when searching).
Peg
~ One of many.
#195298 12/13/2005 6:04 PM
Junior Member
Junior Member
Will send some better shots soon, I have cleaned it up a bunch and it's looking good.Thanks Chris
#195299 12/13/2005 7:36 PM
Man, what a score. That's definately is a 40 GMC. A rare vehicle and looks to be in excellent condition. You done good. Very, Very Good.
#195300 12/13/2005 9:09 PM
Niiiiice truck.
1954 GMC De Luxe COE
#195301 12/13/2005 9:56 PM
Junior Member
Junior Member
Thanks alot it's pretty darn nice shape it has a few issues but nothing major.I am going to try and get a few more shots this weekend to put up.
Chris
#195302 12/14/2005 4:58 PM
dad6timz - You can get the chevy repro ID plate from most of the vendors. I think I got mine from Jim Carter. You'll have to stamp your own numbers into it.
George
#195303 12/14/2005 7:54 PM
46forme tankyou for the info
#195304 12/14/2005 7:56 PM
by the way it's thank you not tankyou
#195305 12/14/2005 9:59 PM
You can edit your posts - just click on the icon with the paper and pencil.
woodythx138 - the guys at www.oldgmctrucks.com would LOVE to see that rig.
