| | | Forums66 Topics128,051 Posts1,055,734 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 35 Junior Member | | Junior Member Joined: Dec 2005 Posts: 35 | Were is the vin located ,did they use the orig eng, # or the body tag # which is Model # AC101 Serial # 12225 Are there any repo vin tags or ID tag availible by the way this is in Calif so anyone know what they used as the vin # .Was it the engine # or the model /serial # Thanks Chris | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Chris - I think your 40 is going to be like my 46. There are no "vin" numbers on them. There should be a metal tag on the right side of the cowel. Which from the numbers you gave I assume is still there. This is what the CHP will use to register your truck. If you don't have the cowel tag the CHP will issue you a "blue tag" with a new ID number for your truck. This is what I had to do, even though I had the numbers off the ID plate (but no plate). I did order a repo plate and stamped my numbers into it but the blue tag is still the registration number. Good luck with your project, it sounds like a good one. George | | | | | Joined: Dec 2005 Posts: 35 Junior Member | | Junior Member Joined: Dec 2005 Posts: 35 | George ,Thanks for the info, I figure the tag I have is what it should be.When you say right side of the cowl is that looking at it or sitting in the cab looking out.Is the AC101 -12225 The correct body tag #s. Chris | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | 'right side' = passenger side
Just after the passenger side door, on the cowl area under the hood, there outta be a metal plate that has stuff like the vehicles GVR, MFG, etc.. on that plate the vehicle serial number should be stamped.
I've heard of California 'VIN' numbers being the original serial number, the engine number, a combination of both, or a totally unique number all together.
Guess it just depends on their mood that particular day, but it seems like in all cases, a new plate was issued with the number on it.. in some cases, the original mfg tag was removed and the state issued plate installed in its place.
| | | | | Joined: Dec 2005 Posts: 35 Junior Member | | Junior Member Joined: Dec 2005 Posts: 35 | Ya I guess it all depends on there mood, they are pretty easy were I am at , they will make me do a vin verification which is no big deal,Thanks for the info. Chris | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | The ID tags are different on GMC and Chevy. The original GMC ID tag was on the interior firewall above the transmission in 1940. GMC ID tags are not reproduced. | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | So is it a Chevy? Post some pics if you get a chance.
I had to blue tag my 1940 3/4 ton. The CHP was actually very good about it. | | | | | Joined: Dec 2005 Posts: 35 Junior Member | | Junior Member Joined: Dec 2005 Posts: 35 | It's a GMC and I sent in pictures to be posted unless there another area to quick post pictures. I have the ID with the model# and serial # and will just use that as the vin # pluss I have the orig 1940 plates for it.Chris | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | 46forme can you tell me where you got the repo plate thanks | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Chris, I was just about to post that your \'Burb is now in the Gallery. Not sure if this will help. But let me know if it gives you more info to add to your page (to help others when searching). Thanks, Peg
~ One of many.
| | | | | Joined: Dec 2005 Posts: 35 Junior Member | | Junior Member Joined: Dec 2005 Posts: 35 | Will send some better shots soon, I have cleaned it up a bunch and it's looking good.Thanks Chris | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Man, what a score. That's definately is a 40 GMC. A rare vehicle and looks to be in excellent condition. You done good. Very, Very Good. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | | | | | | Joined: Dec 2005 Posts: 35 Junior Member | | Junior Member Joined: Dec 2005 Posts: 35 | Thanks alot it's pretty darn nice shape it has a few issues but nothing major.I am going to try and get a few more shots this weekend to put up. Chris | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | dad6timz - You can get the chevy repro ID plate from most of the vendors. I think I got mine from Jim Carter. You'll have to stamp your own numbers into it. George | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | 46forme tankyou for the info | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | by the way it's thank you not tankyou | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | You can edit your posts - just click on the icon with the paper and pencil. woodythx138 - the guys at www.oldgmctrucks.com would LOVE to see that rig. | | |
