8 members (SammyC60, TUTS 59, 52Carl, Mike Roache, TooMany2count, Hawkman, Otto Skorzeny, 1 invisible),
101
Mod | | | Forums66 Topics128,101 Posts1,056,518 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | These two new ones have been around awhile. Mike Gilman's 1948 GMC 1/2-Ton Update -- "GMCPic" has been making good progress in these last five years. He's done all the work himself mostly on weekends. It's looking pretty good. Dennis Johnson's 1954 GMC Aircraft Tug -- This is something to see. When I first opened the pictures, I thought "what???" Would make a great truck -- talk about a "back seat driver" Peg
~ One of many.
| | | | | Joined: Feb 2005 Posts: 68 Member | | Member Joined: Feb 2005 Posts: 68 | That tug is a trick with a hole in the middle of it. never seen anytyhing like it hmmm vry intresting. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | The tug body would make a great crew cab on a custom truck. -W | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | The tug's windows in the "rear" of the cab allowed the driver to keep an eye on the towbar to the airplane. Woog's right, this would make a sweet crew cab for a hauler! Allows great visability on the car you're hauling, too!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I've actually seen, two more of these trucks. One was on ebay, several years ago. This one may have been built, in '54, but that's a '53, & earlier cab/cabs. | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Not sure if this will help, but Frank McMullen sent in this picture which looks a lot like Dennis' deal ... but all in one piece. Frank's message: "A friend found this somewhere on the 'net ... looks like a really huge airfield tug; don't know who the truck builder was but they used '52-'53 AD Chevy/GMC cabs... "Figured that someone here in Stovebolt world can pin a defnitive ID ..." Peg
~ One of many.
