1 members (Gray_Ghost),
77
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19436 11/06/2002 10:45 PM | Joined: Apr 2000 Posts: 28 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 28 | I am just about to get my 53 3800 frame on wheels, and have run into a small problem. the front drums/hubs i have are the offset type and i want to go with the standard drums. my question is will the front drums from a 58 3/4 ton work on my 53 axle?? i am considering buying a parts truck (58 3600) and need to know if they will work. | | |
#19437 11/07/2002 5:18 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I do not recall if the spindles are the same diameter.If no one gives and educated/experienced answer ,call an auto parts store and see if the bearings are the same.If they are, they should swap ok One more thing to consider, the front brakes on a 1-ton are 12 inch and the ones on the 3/4-ton are 11 inch.You will need to swap the backing plates to fit the smaller drums if, IF they will fit the spindles
#19438 11/09/2002 6:52 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Phil,
From the '59 parts book.
HUB, Front Wheel
47-59 3/4, 1 TON w/sgl. wheels ... (cast 3683232).....p/n 3683232
47-59 1 TON w/dual wheels, 53-59 3/4 TON w/dual wheels (exc. D-D), 55-59 D-D w/dual wheels (2nd series).. ...(cast 3683818).... p/n 3683818
KNUCKLE-SPACER, Steering (with nut)
53-59 3/4, 1, 1-1/2 TON (exc. D-D, SBC, hvy. duty)...(forged 3698332)..p/n 3703563
Hubs are different but spindles are the same so it looks like your good to go with the 3/4 ton parts.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
