1 members (walterhvogel), 87 guests, and 3 robots.
Topics128,035
Posts1,055,559
#193599 11/15/2005 8:13 PM
I'm getting close to finishing the 235 installation in my 1940 GMC. I bought 2 new braided ground straps (long and short ones) but I'm not sure where they should attach. Any ideas??
Steve
See my 1940 GMC Pickup:
http://community.webshots.com/user/ndnchf
See my 1940 Canadian GMC:
#193600 11/15/2005 8:22 PM
I only used one on my 55.Attach it from the engine to the frame.
#193601 11/15/2005 8:23 PM
#193602 11/15/2005 8:44 PM
Junior Member
Junior Member
It wouldn't be a bad idea to put one from engine to frame and the other from engine to body or frame to body.
RB
#193603 11/15/2005 8:51 PM
Specifically, where on the engine and frame should they attach?
Steve
#193604 11/15/2005 11:43 PM
My '42 2 ton (235) worked great with a braided ground from the battery directly to the transmission.. I added another from the engine to the frame just for good measure.
My '46 1/2 (216) ton has a single ground going from the battery to the bell housing, and seems to work just fine.
I've learned in my limited experience with 6 volt systems, you can't ever have too many solid grounds, or too big a gauge battery cables!
#193605 11/16/2005 12:47 AM
I'd ground the engine and transmission to the frame. Clean the frame & engine paint off and tin the ends of the braided strap on both ends.
Jim & Caroline
#193606 11/16/2005 1:10 AM
I found the best reference for the correct placement of the factory grounding straps is per the Factory Assembly Manual. I was able to locate the correct locations per my manual covering '64-'66 model years. Good luck.
