1 members (NJC),
125
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | I'm getting close to finishing the 235 installation in my 1940 GMC. I bought 2 new braided ground straps (long and short ones) but I'm not sure where they should attach. Any ideas?? Steve See my 1940 GMC Pickup: http://community.webshots.com/user/ndnchf | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I only used one on my 55.Attach it from the engine to the frame. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I only used one on my 55.Attach it from the engine to the frame. | | | | | Joined: Mar 2005 Posts: 6 Junior Member | | Junior Member Joined: Mar 2005 Posts: 6 | It wouldn't be a bad idea to put one from engine to frame and the other from engine to body or frame to body.
RB
| | | | | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | Specifically, where on the engine and frame should they attach?
Thanks, Steve | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | My '42 2 ton (235) worked great with a braided ground from the battery directly to the transmission.. I added another from the engine to the frame just for good measure.
My '46 1/2 (216) ton has a single ground going from the battery to the bell housing, and seems to work just fine.
I've learned in my limited experience with 6 volt systems, you can't ever have too many solid grounds, or too big a gauge battery cables!
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | I'd ground the engine and transmission to the frame. Clean the frame & engine paint off and tin the ends of the braided strap on both ends.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I found the best reference for the correct placement of the factory grounding straps is per the Factory Assembly Manual. I was able to locate the correct locations per my manual covering '64-'66 model years. Good luck. | | |
