| | | Forums66 Topics128,032 Posts1,055,438 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Hi; I am working on a 1942 Chevy 3/4 ton and have installed a fuel pump that has an auxillary vacuum pump on the top of it. Do I hook up that vacuum line to my regular vacuum line from my intake manifold???? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | repguy, I saw this question not long ago and did a search for it..no soap. If I remember correctly, the vacuum portion of the fuel pump is hooked in series with the manifold and the device being powered. So you are right, the manifold line goes to the pump and the pump goes to the wipers etc. Hope this is right... Stuart | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=010204#000007 | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | repguy, Thats the post I couldn't find...tclederman to the rescue! Stuart | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | The vacuum line from the manifold goes to the fuel/vacuum pump the line then goes from the other side of the pump to the wipers. Just make sure you hook them up to the proper side or you will have no vacuum at all. The purpose is to supply vacuum to the wipers when manifold vacuum is low on acceleration. | | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Thanks to all for you help and info...the Stovebolters RULE again! Brian | | |
