Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#193129 11/10/2005 12:34 AM
Should the truck stay running when the battery cable is removed?
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#193130 11/10/2005 12:56 AM
Yes
Evan
#193131 11/10/2005 1:27 AM
Ok,it curently does not.Now if i ground the field terminal on the generator with the engine running it should stay running with the battery cable removed.?
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#193132 11/10/2005 1:31 AM
are you checking to see if the gen is charging,,if so why not use a volt meter
Redryder pix
My Hotrod
#193133 11/10/2005 1:42 AM
Slow,
The manual for my 46 says with or without field term grounded, you can touch the gen term to a ground and it should spark if you gen is charging. If no spark from the gen terminal cable, no charge. If it is sparking, it is your battery or Voltage Regulator..or a loose connection somewhere...
It should stay running if the gen is charging.
#193134 11/10/2005 1:56 AM
gee yuh mean that neat lookin digital thing with the dial and a whole lot anumbers thats hangin in the shop? cuz i aint sure how ta use it.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#193135 11/10/2005 2:06 AM
just thought it would be quicker, and I am sure you could use it, and read it better then I... I heard that you could remove a cable and check alt that way, was not sure about the gen,, probably not a good method with all the computer stuff on the new stuff,,,,no way did I mean to insult your mechanical or electrical skills........regards....Fred
Redryder pix
My Hotrod
#193136 11/10/2005 2:26 AM
Fred, i was going to say after all these years now i know why youre called joker. :p Im not insulted, just a little dumbfounded by electrical stuff..
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#193137 11/10/2005 2:30 AM
me too, enjoy your web-site, would love to have that 59 scooter,, saw one at them at a meet a few weeks ago, those and the mustangs are really bringing big money when restored,,, regards..Fred
Redryder pix
My Hotrod
#193138 11/10/2005 3:06 AM
Thanks fred,ill have to add some finished pics of the scooter.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#193139 11/12/2005 8:30 PM
Quote
Your right, it would cause a voltage spike and could fry the computer.
#193140 11/13/2005 6:37 PM
Junior Member
Junior Member
Hi, In the old days of no on-board computer, we would ground the field to see if the generator is producing a charge. If so, we'd replace (or adjust) the regulator. If the engine runs with the battery cable off and the field terminal grounded, the generator is working.
Did you try polorizing the voltage regulator? Battery to generator? Yeah, you tried that.
Rich
