Just a li'l info if anyone's interested, I'm buildin a copy of the Li'l Rascals bolt, as seen the features section. My 53 is now sitting on a 79 Cutlass chassis, with 350 Olds motor, ps, pb, & tilt. The overall height is now 12 inches lower than original, and it's 11 inches shorter(I sectioned the bed, so the fenders would sit center over the wheels, then built a tailgate out of 1.50 tubing, this will be covered with sheetmetal. I also will be installing suicide hinges, and bear claw latches with remotes
