2 members (Johnnydog, 78buckshot), 60 guests, and 2 robots.
Topics128,060
Posts1,055,832
#192328 10/30/2005 7:29 PM
I have seen many references to Huck style brakes. What are Huck brakes?
Stuart.
#192329 10/30/2005 8:16 PM
I do not know why they are called Huck brakes, but if you go the link below you can see a picture.
http://chevy.tocmp.com/1947truckshop/47ctsm0502.htm
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#192330 10/30/2005 8:29 PM
I have Huck brakes on my 49 and contrary to the negative reports about them, I am happy with mine.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#192331 10/30/2005 11:04 PM
I have huck brakes on my 46, and as long as your shoe linings are good, there really aren't too many bad things to say about them.
Basically, they're drum brakes that put equal pressure on both shoes, unlike modern "Bendix" drum brakes, which puts more pressure on one shoe than the other.
And that's pretty much all I have to say about them. [shrugs]
They're brakes. You've seen one set, you've seen 'em all.
#192332 10/31/2005 1:39 AM
I wonder, are the fasteners used on Huck brakes "huck" fasteners? That may be the source of the name.
#192333 10/31/2005 9:12 PM
Quote
That is a very good question. One that i do not know the answer to.
#192334 10/31/2005 10:57 PM
Riding in the Passing Lane
I think Huck was a brand name like Bendix or Wagner. They were shure better than the old mechanical brakes but the bendix style are better & easier to work on. Chev. used them on 1/2 ton trucks & cars through 1950. 3/4 ton used them a couple of years longer.
1972 Chevy c10 Cheyenne Super
#192335 11/01/2005 1:07 AM
Hey Wrenchbender,My52 1Ton has Huck Brakes all the way around cool Regards steve sr.
#192336 11/01/2005 12:46 PM
The difference between Huck and Bandix is that in the Huck breaks you got two independend shoes and so the front shoe has more work to do than the back shoe.
In the Bendix setup both shoes are connected and act like one big shoe, wich gives a bit more break power and equal wear.
If correctly maintained the break power in both systems are almost the same. wink
Frank
#192337 11/01/2005 1:34 PM
There is a statement, either in the GMC manual or the Chev manual about the rear shoes lasting twice as long as the front shoes, I am talking per wheel that is.
1951 1 Ton Completed
#192338 11/01/2005 4:11 PM
Jim & Caroline
