0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#191867 10/22/2005 12:02 PM
Junior Member
Junior Member
First let me thank you for all the help from my last post, "Beat It With A Hammer"!
Truck is running fine with one (or 100) little problems. Fuel leeks from the Throttle Flange Assembly. To be specific, from the butterfly pivot(?)at the front of the carb (rochester).
I don't see any way to dissasemble, no parts in my "Carb Rebuild Kit". Should I just buy an entire carb and be done with it?
Thanks in advance.
Bob
#191868 10/22/2005 5:12 PM
Bob,
Maybe some else will pose a good way for you to fix this common probem. I think that bushings in the carb body are needed on each side of the pivot. A new/rebuilt carb is a practical solution (you trade-in your old carb either as core-swap or to be a rebuilt). NAPA, Advance Auto, and Auto Zone (and other suppliers) might be able to supply a well-rebuilt carb.
Be careful having a (non-carb specialty) shop rebuild your carb - most just clean the carb and install the same kit that you have.
Do you want the name of a few good carb rebuilders (they are not cheap but the know what they are doing and they stand by their work).
I have not had good luck with rebuilt Rochester carbs from Jim Carter (but, he might not still sell them).
Tim
#191869 10/22/2005 9:32 PM
Riding in the Passing Lane
Is your carb flooding? After you shut it off look down the throat. If any gas is dripping in you have a flooding problem & gas is building up around the trottle plate. It could be caused by a piece of dirt in the needle & seat or float level set to high. Check your float & make shure it does not have gas leaking into it.
1972 Chevy c10 Cheyenne Super
#191870 10/23/2005 12:57 AM
Socket Breaker
Socket Breaker
Listen to Wrenchbender, he knows much. grin
-W
#191871 10/23/2005 3:01 AM
Junior Member
Junior Member
The float is new and I have gone through the carb as far as cleaning and replacing all the parts that come in a rebuild kit. The truck runs good and idles smoothly so I don't think it is flooding.
Tim, I would be interested in any good carb rebuilders, don't mind spending the dough for quality work! Lots of winter projects planned, might as well as add another one!
Bob
#191872 10/23/2005 3:59 AM
Big Pop,
Larry Isgro Carburetor Rebuilders
1604 Argyle Road,
Wantagh, NY 11793
516-897-0401 Shop
Also,
CarbKing , who frequents this forum, is also held in high regard.
Tim
#191873 10/23/2005 10:18 AM
Junior Member
Junior Member
Thanks Tim.
Gonna check the float level and needle as Wrenchbender suggest one more time. If that don't work, off to the rebuilder!
Bob
