3 members (RLB, Oswald, GRNHydra),
86
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 21 Junior Member | | Junior Member Joined: Dec 2004 Posts: 21 | First let me thank you for all the help from my last post, "Beat It With A Hammer"!
Truck is running fine with one (or 100) little problems. Fuel leeks from the Throttle Flange Assembly. To be specific, from the butterfly pivot(?)at the front of the carb (rochester). I don't see any way to dissasemble, no parts in my "Carb Rebuild Kit". Should I just buy an entire carb and be done with it?
Thanks in advance.
Bob | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bob,
Maybe some else will pose a good way for you to fix this common probem. I think that bushings in the carb body are needed on each side of the pivot. A new/rebuilt carb is a practical solution (you trade-in your old carb either as core-swap or to be a rebuilt). NAPA, Advance Auto, and Auto Zone (and other suppliers) might be able to supply a well-rebuilt carb.
Be careful having a (non-carb specialty) shop rebuild your carb - most just clean the carb and install the same kit that you have.
Do you want the name of a few good carb rebuilders (they are not cheap but the know what they are doing and they stand by their work).
I have not had good luck with rebuilt Rochester carbs from Jim Carter (but, he might not still sell them).
Tim | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Is your carb flooding? After you shut it off look down the throat. If any gas is dripping in you have a flooding problem & gas is building up around the trottle plate. It could be caused by a piece of dirt in the needle & seat or float level set to high. Check your float & make shure it does not have gas leaking into it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Listen to Wrenchbender, he knows much. -W | | | | | Joined: Dec 2004 Posts: 21 Junior Member | | Junior Member Joined: Dec 2004 Posts: 21 | The float is new and I have gone through the carb as far as cleaning and replacing all the parts that come in a rebuild kit. The truck runs good and idles smoothly so I don't think it is flooding. Tim, I would be interested in any good carb rebuilders, don't mind spending the dough for quality work! Lots of winter projects planned, might as well as add another one!
Bob | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Big Pop, Larry Isgro Carburetor Rebuilders 1604 Argyle Road, Wantagh, NY 11793 516-897-0401 Shop Also, CarbKing , who frequents this forum, is also held in high regard. Tim | | | | | Joined: Dec 2004 Posts: 21 Junior Member | | Junior Member Joined: Dec 2004 Posts: 21 | Thanks Tim.
Gonna check the float level and needle as Wrenchbender suggest one more time. If that don't work, off to the rebuilder!
Bob | | |
