3 members (KEVINSKI, Gray_Ghost, Otto Skorzeny), 113 guests, and 4 robots.
Topics128,100
Posts1,056,513
Members48,448
My '46 1/2 ton has a 4 speed transmission and that stupid "torque tube" U joint driveshaft thing.. which looks to be a regular u-joint inside a tube.
I need a supplier for the bolts, berrings and metal deal that you need to put the joint together.. looks identical to what my '50 1/2 ton truck had.. but i'm not sure that it IS identical.
Any help or sources are greatly appreciated!
Jed Offline
Fumblin,
Check Chev's of the 40's. They're on the web.
www.chevsofthe40s.com
Looks like that outfit wants you to buy the whole U-joint for $175.. which might not be a bad idea.. except I don't have $175 to spend on it, and all I really need are the berrings, the four bolts, and the two pieces that "close" the joint.
[img]http://www.oldtruckstuff.com/ujoint.gif[/img]
What I need is the bolts and metal deal circled in green and the berring that slips over the spot labled "A"... x2.
F46, Jim carter shows to have a universal joint repair kit for 1940-54 halfton only, 3 and 4 speed for $41.85 part number me453
the u-joint complete is $110.75 1940-47 3 speed only
universal joint lock clip..1940-1954 halfton , 3 and four speed,,,$2.30(included in above kit)
drive shaft housing and bell gaskets 1935-54 half-ton short bed,,,$10.00
drive shaft bushing and seal assembles 1940 to 50 halfton $67.55
drive shaft torque tube seals only
1940-50 halfton 10.75 but is included in the above drive shaft bushing set
at any rate, looks like they may have what you might be looking for. 1-800-872-1913.. good luck..
Fred
Redryder pix
My Hotrod
hi fumblin sent you email..let me know if you got it.mike j
Drive with Pride. mike j
family pic
Got your eMail, and have sent a reply!
Jed Offline
Fumblin,
If you're going the "parts" route, make sure you get the keeper things, with the fold-up ears, that hold the u-joint bolts in place.
The wife looks at me funny whenever I mention I need to buy yet ANOTHER part for one of the trucks.. lol.. i've discovered the higher the price, the redder her face gets.. so I like to get 'em as cheap as possible!
Those "fold up ears" deals are an absolute must have for anything that spins around at any kind of speed (like on the flywheel!) and i've already seen what can happen when those bolts come loose in a torque tube setup.. thats what happened to the '50 1/2 ton!
I guess a squirt of Loc-Tite wouldn't hurt on re-assembly, either.
so that is what happened to my 52 when i installed the u-joints, came apart so I went to a shop and had the s-10 five speed and blazer rear installed grin Fred
Redryder pix
My Hotrod
Fumblin,
I don't know if dakota already helped you out but I have these leftover parts below that might be useful if your interested.
[img]http://img.villagephotos.com/p/2003-9/378428/u-joint.JPG[/img]
John.. yea those end pieces and the berrings (along with the bolts that hold it all together) are what I need. Dakota has a '54 trans sitting in his parts pile with the torque tube still connected and is going to hook me up.
Jim Carters "universal joint repair kit" says it works with 1940 thru 1954 1/2 ton models, so i'm guessing they're the same parts for those model years.
Joker.. i've looked with great interest at the s10 tranny upgrade.. but it's probably a little out of my budget at the moment, especially considering i'd have to pay somebody to do it!
Fumblin: You need to find your wife a hobby of her own. That way, she does her thing, you do yours, neither asks the other one any questions, and everybody's happy! grin
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Socket Breaker
Socket Breaker
Quote
This seems like solid advice fumblin... grin
-W
She has her own hobby.. making lotion, soap and candles.. but financing for each of our respective hobbies comes out of the same collective pot. wink
having proplems with mail again, sent pics. let me know if you got them. can send the parts to Rich on Monday if they will work. mike
family pic
Mike.. I eMailed back.. the pics you provided are exactly what I need, and your micrometer measurments match the parts I have.
Ain't the internet just great? smile
Don't forget the brakes!!! eek
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
Brakes?! We don't need no stinkin' brakes!!
Actually, i'll be messing with the brakes tomorrow. Today I got the regulator re-wired and replaced alot of the shot wiring.. up untill this morning, the engine was running with a jumper wire run from the battery to the coil.
Now she starts with the turn of a key and a stomp of the switch, and most importantly, the generator is working and charging the battery.
So tomorrow is slap on some exhaust pipe and a muffler and bleed the brakes day.
Don't forget to replace that cork seal in the torque tube. I have found that a large O-ring to replace the cork will stop the normal drip from the tube.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
