5 members (55shaker, Shade Baby, greenie-reddy, Gdads51, Pre '68 Dave), 71 guests, and 0 robots.
Topics128,035
Posts1,055,570
#190965 10/28/2005 11:58 PM
Apprentice
Apprentice
Hi all,
The parking brake on my '42 3/4-ton special doesn't work very well. Having it off or applied as hard as I can makes the difference between a truck that I can get rolling with one finger and needing three fingers to push it. The brakes overall work perfectly. They stop great when using the pedal. The pedal throw is only a couple of inches, so I think I have the brakes set up correctly. I found the adjustment point on each P-brake cable such that the brake lever has about 3/4 of its unencumbered travel. Everything seems like it should be working. Any thoughts about this? Is the parking brake really just that bad? Is there something I missed? Thanks for your help.
-Jon
Jon
1942 Chevy 3/4-ton Special
I don't need instructions. I have a hammer.
#190966 10/29/2005 4:24 AM
For instructions on adjusting the emergency brake, go to http://chevy.tocmp.com/1942_47shop/4247csm506.htm
Fred
52 3600
69 C-10
#190967 10/29/2005 4:33 AM
Jon,
I have not familar with your truck..so..Do you have new cables or are the old ones free? My cables were one solid piece of rust so I had to go with new. Your P-brake should be able to lock up the brakes. Since your P-brake uses your rear brakes for holding, something is wrong or not put back together correctly.
