| | | Forums66 Topics128,048 Posts1,055,541 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 39 | I am getting radial tires for my truck from coker and the current size on the 1/2 ton chevy (mostly original)is 7.00 x 16 original rims 6 lug
will 7.50 fit with no problem? they are one inch taller and maybe 1/2 inch wider as far as I can tell...what do you think? thanks! | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | powerband,
I have 7.50 bias ply on 16" rims & did have some problems. Maybe it was just my truck but the king pins had to be replaced & we have two spacers on each front wheel.
On the back we have one spacer on each.
I'm still wondering if they might be rubbing in the back when the bed bounces around.
I hope someone else will also answer this question since I still have my doubts but don't want to get rid of my big, tall, flat faced tires.
Sabrina
Tires show in the Gallery pictures that Peg just put in as Wednesday Gallery Additions. | | | | | Joined: Sep 2003 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 50 | We put Futura Scrambler 215/85-16 blackwall radials on a '54 standard halfton Chevy with original 16X4.5 or 5 inch wheels (can't remember!) These are usually used on dually rearends I think. They ended up being pretty close to what the dimensions are for original bias tires, with tread width and diameter and all, some of that info available in the front of the 54 Chevy Shop Manual. We compared the original dimensions to those listed on the Tire Rack website, a handy reference. They have worked out really well and look great. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | There is a site called "Tire Rack" that lists every tire by dimensions. I replaced a set of 6.50x16 bias with radials. Of course the rim was 6 1/2" and the wheel 16" so all I had to measure was the heigth with the weight on the tire which was 28 1/2". A 225-75-R16 was a match except it was listed as 29.3" tall. Since radials "squish" down some I measured it with the weight on them and guess what--28 1/2".
Evan
| | | | | Joined: Sep 2003 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 50 | Coilover; wasn't your treadwidth much wider than original with 225/75's on your wheels? I was going for a narrow track profile from the front as well as the side height profile. The 215/85s were rated for 5in to 7 in rims, rated for very heavy weight and were a great price at $85 each. | | |
