1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#189304 09/12/2005 4:35 PM
I
I Offline
After having put the alternator from the donor van in the '48 last weekend, I found that it wasn't charging... then the stovebolt page went down and I couldn't ask for help... I searched around the web and found out that the "Dummy" light wire isn't just for "Dummies". It also supplies the power to excite the alternator into action. I installed a dummy light and got the alternator working.
I also started fabrication on the new dump body. The original is beyond salvage. The new one is being modeled after the original, with some minor dimensional changes. When it is done it will look nearly identical to the original.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#189305 09/12/2005 5:14 PM
Jed Offline
Attended 2-shows this weekend. Saturday, I took the 46 to Trapper-Days in Ft. Lupton, CO. Ate some great BBQ.
On Sunday, we had a local show, in the parking lot of a boot/western wear store. I took both the 46, and the 52.
No tropies, but I did walk away with the grand door prize. It's a garage in a box...
It has a pair of chocks, jack stands, a hydraulic floor jack, and a creeper.
Beyond that, just had alot of fun.
#189306 09/12/2005 5:44 PM
Inky, the "dummy" light also tells you instantly if you've thrown a belt. You don't have to wait to notice the engine has overheated.
#189307 09/12/2005 5:59 PM
I
I Offline
Yeah, Cletis, I figured I might as well go ahead and put it in. It's a $2.99 insurance policy.
Hated the thought of drilling the hole in the dash though.
Also, I read somewhere that the exciter wire needed to have at least 35 ohms of resistance to keep from frying the regulator. The bulb provides the resistance.
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#189308 09/12/2005 8:35 PM
I wrenched on the '67 this weekend.. finally got the hang of putting a tire on a rim by hand.. goes pretty quick once you figure out the tricks!
Said goodbye to Ziggy (50 1/2 ton) on Sunday as his new owner (a 17 year old kid who wanted it to pull his home built teardrop trailer!) and as soon as the Okie from Miskokie picks up the '50 2 ton, i'll have some space cleared up to start putting the new box on the '46 big bolt and hopefully start building my new 40x60 garage/pole building.
#189309 09/13/2005 12:21 AM
Went on a cruise, two 55.1 Chevy Pickups. Mine is the "before" examlpe and the other one is the "after" example. Also a '51 Merc and a '55 Buick. Did about 120 miles total, went for the BEST BURGER IN ALASKA at the Monderosa.
Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
#189310 09/13/2005 3:14 AM
Moderator
Moderator
Got the cement project finished up. One more domino down in the garage expansion plan. Also finished a drainage project. Both big jobs and glad to have them finally done. Waiting on a new grandbaby any minute too.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
